tranny issue
Old Jul 29, 2009 | 01:46 PM
broncoderek's Avatar
broncoderek
Sounds electrical. I can't imagine something mechanical being good, then bad, then good again.
Old Jul 29, 2009 | 04:15 PM
ssquints999's Avatar
ssquints999
here are codes i've gotten
when i first changed the solenoid pack i had these.
637 transoil temp circuit above voltage
621 shift solenoid 1 circuit fault
622 shift sol 2 circuit fault
629 converter clutch solenoid circuit fault
626 coast clutch solenoid fault
624 electonic pressure control solenoid circuit fault
then i pulled the negative cable after changing the vss yesterday and had these after i stopped
637 trans oil circuit above max voltage
so i cleared the codes before going home
i just finished getting these
current: 629 converter clutch solenoid circuit fault
624 electronic pressure control solenoid circuit fault
626 coast clutch solenoid circuit fault
stored: 617 shift error 1-2
624 electronic pressue control solenoid circuit fault
628 excessive converter clutch slippage
637 trans oil temp circuit above max voltage
628 and 626 i've had since getting the truck in ocotber and have never had a problem and i would get 617 every now and then.
i pulled the negative cable again and will try to drive it and if it starts working then i'm not clearing codes pulling codes or anything i'm just going to leave it be.
