C6 Specification Question
Old May 13, 2001 | 12:59 AM
Like M. Fords's Avatar
Like M. Fords
I am rebuilding the C6 on my '69 F250 and I am trying to figure out what the pressure plate to snap ring clearence should be for the Reverse-High Clutch. My book says it should be .022-.036, but I am machining the drum for a second snap ring groove to allow for a total of 5 clutches. The .022-.036 specification is for a 3 clutch pack. Would it be the same?
Old May 14, 2001 | 07:36 AM
DeenHylton's Avatar
DeenHylton
I would say the clearances would remain the same, but I would call someone like "B&M" or "TCI Automoitive" to double check your clearance figures. It's been a long time since I've set up a C-6
but your numbers seem a little "tight". I'm assuming your also putting in a shift kit and will be using your tranny in a more performance or competitive nature...that tends to call for different clearance numbers than what a stock C-6 would require.
Deen Hylton
Ford F250 460 C-6, K&N, Headers, Dual Exh.,Comp. Cams,Shift Kit
Pioneer CD w/Bose Speakers.
Other Passion: Blown 77 Corvette (Sorry Guys/Gals)
How I can afford to Drive the above: 93 GEO Metro
Old May 14, 2001 | 06:26 PM
minus's Avatar
minus
036.0stroke
May 29, 2016 09:57 PM
036.0stroke
Mar 15, 2016 08:43 PM
nosehair
Oct 29, 2015 12:40 PM
1972-34ton
Jul 9, 2008 12:08 PM
casevac1
Jul 19, 2003 05:37 AM
