CPS Oil Leak?
Old Jul 8, 2009 | 08:59 PM
Rich in CO's Avatar
Rich in CO
CPS Oil Leak?
My truck was missing while at idle so I swaped my spare used CPS & the miss is gone, but from the best I can tell I have oil leaking from the CPS. Is that possible? I think it did not seat well or the O ring is bad?
When the motor cools down I'm going pull & re-install the CPS or pull the O ring off the spare. When looking at the spare CPS that I pulled & did not leak the O ring is real loose also?
Any Ideas or could the leak be comming from some where else. The HPOP is clean
Old Jul 8, 2009 | 09:21 PM
indyF-350psd's Avatar
indyF-350psd
you can't fix stupid!
its probably coming from the cps. as a rule of thumb the o-ring on those things are shot after you install it. they are a one time deal mostly. you can order some cps o-rings from guzzle's website. always good to have small stockpile of spare o-rings laying around.......
Old Jul 9, 2009 | 06:30 AM
Rich in CO's Avatar
Rich in CO
Thanks Indy, I'll stop by & see Guzzle.
Hussler
Sep 19, 2015 03:54 PM
Farmboypowerstroke
16
Jan 31, 2014 01:01 PM
4inchlovin
26
Apr 7, 2012 08:35 PM
cowmilker08
Oct 11, 2011 11:03 PM
Kenworth
Jul 10, 2006 03:20 PM
