white smoke
Old Jul 8, 2009 | 06:13 PM
6.9lidiguy's Avatar
6.9lidiguy
white smoke
just baught a 1983 6.9l and it is smoking like no other. i first had the injectors tested there all good then ran a compression test all good at 400 then messed around with twisting the ip still tons of white smoke no power and the exaust smells like fuel.
Old Jul 8, 2009 | 08:47 PM
PLC7.3's Avatar
PLC7.3
Any history on the engine...... was it rebuilt, or the IP replaced. When you did the injectors did you replace the return lines and caps........ also replace the copper washers on the injectors..... who did the work.
Old Jul 9, 2009 | 01:43 AM
6.9lidiguy's Avatar
6.9lidiguy
i replaced washers and return lines myself before putting the injectors back in. the ip is a remanufactured from 1999 unsure of its milage. the motor work was supposivly a complete rebuild, but i dont really know because i lean saled it from the owner of the shop. i didnt care so much about the history because i figured the price as right at $350 when he had recieps foe about $2500 in parts and labor. i hope this isint all off topic from what you wanted.
Old Jul 9, 2009 | 02:33 AM
rupejosh's Avatar
rupejosh
it could be air getting in.in a major way.
Old Jul 9, 2009 | 01:12 PM
6.9lidiguy's Avatar
6.9lidiguy
how would i go about checking this because i have bled the injectors and have gotten just fuel also a see no bubbles in the line running back to the fuel water seperator. my guess is that the pump is either injecting at the wrong time or just injecting way to much but i just dont know enough about these motors.
Old Jul 9, 2009 | 05:28 PM
FL-Mudd-Duck's Avatar
FL-Mudd-Duck
check injector lines mine did that when i got two in the wrong place
Old Jul 9, 2009 | 06:28 PM
6.9lidiguy's Avatar
6.9lidiguy
u mean u mixed them up on the back of the pump or what? i never thought about that.
Old Jul 9, 2009 | 06:29 PM
6.9lidiguy's Avatar
6.9lidiguy
there is no where else they could get mixed up right?
Old Jul 9, 2009 | 07:30 PM
FL-Mudd-Duck
yea they were mixed up on back of pump on a pump swap. ran like crap and white smoked real bad
Old Jul 9, 2009 | 08:01 PM
6.9lidiguy's Avatar
6.9lidiguy
this truck runs ok just has no power and tons of white smoke. have you ever herd of the pump being 180 out?
Old Jul 9, 2009 | 08:15 PM
FL-Mudd-Duck
i say run like crap . it idled and reved up fine just white smoked and had no power. never heard of one being 180 out . pump only goes on one way unless ip gear moved
Old Jul 9, 2009 | 09:08 PM
6.9lidiguy's Avatar
6.9lidiguy
yea the pump spins once for every two revolutions of the motor so i guess it can be off by one rotation and still run just not run good.
