help
Old Jul 8, 2009 | 02:29 PM
joe f350's Avatar
joe f350
Cool help
http://www.youtube.com/watch?v=9QsvTRkr5sI
Old Jul 8, 2009 | 03:31 PM
wreckinball's Avatar
wreckinball
well joe that connection on the back looked like the oil pressure sending unit and yes that thing you called a CDR valve was correct. You may not need to replace it so check it first, if it is really old then go ahead anyway. As for the fuel problem, i am not sure, sounds like air in lines but if some are bleeding and some are not, i would say the IP is having some issues.
Old Jul 8, 2009 | 07:01 PM
joe f350's Avatar
joe f350
its making me so mad
Old Jul 9, 2009 | 02:08 AM
rupejosh's Avatar
rupejosh
do you have an electric pump layin around?
Old Jul 9, 2009 | 03:06 AM
joe f350's Avatar
joe f350
no is there a role switch in the tank seltor value
Old Jul 9, 2009 | 10:52 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Joe there are three wires in the selector valve for fuel gauge sending unit to fuel gauge connections.
Yellow with white stripe goes to the gauge.
Yellow with light blue stripe to the rear sending unit.
Dark blue with yellow stripe to the front sending unit.
Brown with white stripe and black are the leads that run the motor to switch tanks that go to the switch in the dash.
Right now I can't find the wire locations on the plug though.
Old Jul 10, 2009 | 12:51 AM
joe f350's Avatar
joe f350
thx dave every bit helps
