Does anyone know how hard it would be to swap out a AOD out of a 85 F-150, to like a 4-speed any ford kind, or a ZF, T-5, or if i get a good deal M5OD,? Thanks
Nick,
"Speed equals money how fast do you want to go?"
Horsepower tv guy the fat one.
rebuild the aod and keep it.
but, if you must row around with a shifter, don,t get the m5od even if it is free. it is junk.
the t5 will locate the shifter under the seat, so, this leaves you with a zf if you want overdrive and granny gear. if you want a real off road box, get a t18, t19, or np435. these have granny low, but no overdrive.
there are other overdrive manual units, but most are for lighter duty.
I know whats available, but the AOD rebuild costs 800, and I'd figure I could get a good used Manual for that? I'd love to have a 5, but 4's are alot stronger, I'm told. So what would I have to do to change, clutch etc? How much money am I lookin at?
Thanks,
Nick
in my opinion it would cost more than 800.00 to change everything over unless you can get a whole truck cheap, i cant find a 5spd for uner 750.00. my 2 cents
87 f-250
" if you are going to have a bear, it might as well be a grizzly"
4.9 granny tranny 4.11 gears
