wiring harness part #'s???
Old Jul 7, 2009 | 05:41 PM
shanes66charger's Avatar
shanes66charger
hey guys, I am trying to hunt down some wiring harnesses for my 78 f-150.
I'm looking for the main harness that has the fuse block on it, the engine harness, both light harnesses and the frame/tailight harness.
If anyone with the books etc. could possibly find these numbers for me I would appreciate it Immensly!
My truck is a 1978 f-150 300-6 4-speed. It has dual tanks, idiot lights for alt and oil and NO a/c. IF you could find a number for one WITH a/c and dual tanks that is fine too as I have an A/C cab I might use.
thanks in advance!
Old Jul 7, 2009 | 08:10 PM
mikeo0o0o0's Avatar
mikeo0o0o0
There are three different wiring harnesses listed depending on the serial number of your truck. All fit 1978 model F100-350, either 6 or 8 cylinder, warning lights, with auxilliary fuel tank. No distinction made as to transmission or with/without A/C (I believe that is a separate wiring harness).
Part Number D8TZ-14401-F before s/n BE0,001
D8TZ-14401-M s/n BE0,001>CA0,001
D8TZ-14401-U from s/n CA0,001
This is the main harness that has the fuse block on it and goes under the dash.
Hope this is what you're looking for.
Old Jul 7, 2009 | 08:28 PM
shanes66charger
yes, I would like to find the light harnesses etc also, but this is the MAIN one. how do I find my serial numbers? None of those correspond to my VIN etc???
Old Jul 7, 2009 | 08:42 PM
bigdavesohc's Avatar
bigdavesohc
Where can you get said wiring harness? And how much do you need to shell out?
Old Jul 7, 2009 | 08:54 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Here are some more numbers:
D7TZ-13076-A Headlight wiring assy. includes parking lamp and marker lamp leads
D7TZ-14289-M Dash> engine feed, 300 6 cyl.
The frame harness has several different versions depending on 2wd/4wd, wheelbase w-w/o camper special pkg. etc. ( I counted 5 different harnesses).
Old Jul 7, 2009 | 08:59 PM
mikeo0o0o0's Avatar
mikeo0o0o0
The serial number is the last part of your VIN number (example F10BNCE6879, The serial number is CE6879)
Old Jul 7, 2009 | 09:13 PM
shanes66charger
ok i got it figured out. Just wasn't pickin up what you were puttin down for a minute there!
Old Jul 7, 2009 | 09:18 PM
shanes66charger
ok mike. thanks a ton so far! If I could be so kind (no rush) to help out with the frame harness a bit more specifically?
mine is 78 f-150 4wd 300-6 4-speed (NP-435) Eight foot bed. NON camper special etc. NO trailer brakes etc. Just the standard unit.
Could you possibly post those five part numbers please?
Don't imagine you have any idea what the difference would be on that man harness in regards to serial numbers?
Old Jul 7, 2009 | 10:57 PM
mikeo0o0o0's Avatar
mikeo0o0o0
The p/n for the frame wiring harness is D8TZ-14405-G
'78 F150/250 Reg cab, 6 or 8 cyl., 4WD, 133" WB, w/o camper special pkg.
As for the differences between the main wiring harnesses. I wouldn't have a clue as to what they are. The only people who knew are probably dead and buried by now, or at least well into their retirement years.
The other part numbers for the frame harness are all the same basic number and prefix, only the suffix letter changes, so the other harnesses are p/n D8TZ-14405-D, B, L, F, H, P, or K. There are actually 8 different harnesses, The list continued onto the next page and I didn't catch that until now.
Old Jul 7, 2009 | 11:26 PM
shanes66charger
was the first number you listed for dual tanks? Or maybe It doesn't specify?
huge thanks again mike! I owe ya.
Old Jul 7, 2009 | 11:57 PM
mikeo0o0o0's Avatar
mikeo0o0o0
I went back and checked, it doesn't say anything about aux. fuel tank on any of them.
My guess (and thats all that it is) is there is an additional harness for the dual tanks or the harness has the wiring in it for the aux. tanks, if you don't have the second tank you'll have an unused plug on the harness.
Old Jul 8, 2009 | 12:04 AM
shanes66charger
thanks again man! having good locating wiring other than the frame harness. figures, its in the worst shape LOL
JClark785
Nov 13, 2016 07:52 PM
Shortbox4x4
May 25, 2016 08:09 PM
Andrew James
Jan 2, 2013 06:55 PM
davidsca
Electrical Systems/Wiring
Mar 29, 2006 06:56 PM
CountryBoy685
Feb 11, 2003 04:20 PM
