Starting Problem?????Input PLEASE
Old Jul 7, 2009 | 12:40 PM
slightly-stoopid's Avatar
slightly-stoopid
Hey all first time on this site. I have a 06 XLT 4x4, when i go to start it, it sometimes sounds like when your car is already started and you try to start it again you know. It seems to do this maybe 1 out of 20 starts, but once it does it I wait a sec and try again and it turns over fine. Any advice would be great. Thanks guys.
Old Jul 7, 2009 | 01:56 PM
slightly-stoopid
Common Guys takes 2 mins to help me out.
Old Jul 7, 2009 | 01:59 PM
Fishin76's Avatar
Fishin76
I would replace your starter soon, sounds like the bendix gear is not working right. may leave you stranded one day.
Old Jul 8, 2009 | 06:08 AM
slightly-stoopid
Is the bendix gear and the starter connected somehow???
Old Jul 8, 2009 | 09:30 AM
Fishin76's Avatar
Fishin76
ya, the bendix gear moves up the starter shaft when the starter spins, engaging the flywheel and turning the engine over to start it. When it sticks, the bendix does not slide up the shaft, The starter just spins, not turning over the engine.
You may be able to take the starter out and spray the bendix gear and the mechanism with white lithium grease. That may keep it from sticking,
anybody else have an idea how to keep a bendix from binding or sticking?
Old Jul 8, 2009 | 09:58 AM
slightly-stoopid
Thank you for your input very helpful stuff.
Old Jul 8, 2009 | 03:59 PM
mercman86's Avatar
mercman86
Just replace the starter, then you'll be fine!
Old Jul 8, 2009 | 04:27 PM
xjcamaro89's Avatar
xjcamaro89
X2 on the replaceing starter, if your going to pull it out to lube it and that might fix it for now, you might as well put a new one in. Just my thoughts.
Old Jul 8, 2009 | 04:59 PM
mercman86's Avatar
mercman86
yep, dont bother trying to lube it cause you'll just end up having to pull it off when it fails again.
Old Jul 8, 2009 | 05:26 PM
1saxman's Avatar
1saxman
Plus the gear could be damaging the flywheel gears if it's not completely engaging them as it seems like it might be from your post. I would have that replaced. If you do it yourself, be aware that some starters need to be shimmed to get that engagement just right, and some don't.
Old Jul 13, 2009 | 06:45 AM
slightly-stoopid
Thanks alot guys.
