cold air intake?
Old Jul 15, 2009 | 11:51 AM
rebelchevy02's Avatar
rebelchevy02
Originally Posted by strokersace
Mike-
Have you ran the Tymar or 6637 at all? If so, was there a difference between it and the 6oh?
I have not ran the Tymar or 6637, HOWEVER, others have ran the AFE II and the tymar, and noticed little difference. IMO the biggest difference between the 6oh, and AFE II is the absence of noise, and better UOA's. (Silicon level)
Originally Posted by Izzy351
So in order to use the 6.0 setup, it looks like you have to switch to the early 99 style intake tube (shorter than the later style), and it looks like you plumbed in the stock CCV (evident by the dirty, oily boots ). I wouldn't do that if I tried this approach, but the question I do have is what is that large hose on the front end of the filter? Looks like a small radiator hose or something. What's it for?
I have a buddy that I might be able to talk out of his stock 6.0 system, so I'm curious. And does it just lay in there or did you have to come up with some custom brackets? Does the actual intake sit where the stock snorkel comes out?? May be something for me to try relatively easily to see if there are any differences in the air temps post-I/C...
I have an ATS compressor housing. It comes with a new inlet boot. It is between the compressor housing, and a piece of 4" exhaust tube. Which connects to the OEM turbo boot, that I cut down, to fit inbetween the ATS boot, and the 6oh intake. The hose on top of the intake, is for the CCV inlet, someday I will do as CLUX has, and put in the oil trap that I have already even built. Personally, I have no issues with oil being on my boots. Think preservation. 7 years, and 212,000 miles, still OEM boots. The hose on the front of the filter is a hose that is installed OEM on the 6oh setup. Im not sure the purpose, but I just left it there. If you decided not to plumb the CCV in on the top as I did, you will have to plug the hole, that is left from were the MAF sensor would have went OEM on the 6 leakers. If you or anyone needs more info, or pictures, its probably easiest to call me, so pm for cell. I have no issue talking about trucks, just bad at all the small talk haha.
Old Jul 15, 2009 | 12:08 PM
03_PSD's Avatar
03_PSD
That's the first time I've ever seen or heard of someone putting on a 6.0 intake. Looks kinda neat.
Old Jul 15, 2009 | 12:19 PM
F350-6's Avatar
F350-6
Clux has been running one for a while now.
Old Jul 15, 2009 | 12:21 PM
rebelchevy02
Yea, he would be my inspiration/ pictures / info for why mine is how it is.
Old Jul 15, 2009 | 01:28 PM
03_PSD's Avatar
03_PSD
First time I've seen it, very cool!
Old Jul 15, 2009 | 03:45 PM
blue1ton's Avatar
blue1ton
I have the AIS with the optional Sleeve cold air set-up. Although there are other good set ups, I really am glad I have this set up with the MBRP exhaust.
Old Jul 15, 2009 | 04:50 PM
Izzy351's Avatar
Izzy351
I have the ATS as well -- I was referring to the intake tube that went between the CCV coupler (or bypass part) and the stock air box. The early 99 has a shorter tube, but I guess you just cut down the stock one. I don't want to do that, so I'll look at other options (like the early 99 tube) in case I want to switch back to the 6637.
Thanks for the info!!
Old Jul 15, 2009 | 05:49 PM
rebelchevy02
I originally had the ccv coupler in there, but IIRC when I put the 6oh intake on, I am pretty certain there would have too much misalignment to connect between the CCV coupler, and the 6oh intake. So I removed the CCV coupler, and used a small piece of 4" exhaust. (as you call the bypass part)
Old Jul 15, 2009 | 05:52 PM
fnx4wheeler's Avatar
fnx4wheeler
When I had my AIS, it would peg the filter minder. My truck is a pretty heavy one (9k+, scale verified) and tows skid loaders, etc. The AIS did not cut it for me, even with the zoodad, and fendersleeve. Others have had better success then me. Could have been a fluke. The 6oh setup has the same filtering efficiency as the AIS, and is much cheaper then the AFE, other then its a little more work, Im not sure why the AFE would be the choice over the 6oh setup. I have ran the AFE II, stock, and 6oh. 6oh being my favorite of all.
I've read about the 6.0 set up but am not familiar with it. Is it cheaper than the AIS and flow more air? I saw an AIS for $219.
Old Jul 15, 2009 | 07:52 PM
rebelchevy02
Usually you look for someone who just "upgraded" to an aftermarket filter setup for their 6leaker. They usually give them away or ask $50 or so, last I looked. (when I got mine) Most expensive part is really the filter. Ultimately what you want is the battery tray, and both sides from the filter. Then get a new filter, which is the middle section, includeing the plastic housing it comes in. Ill look around and see what I have, may have a second one? I cant remember anymore.
Old Jul 15, 2009 | 09:46 PM
clux's Avatar
clux
You don't need to cut down anything, just replace the CCV coupler with a short piece of exhaust pipe and it all will work with the stock parts.
Old Jul 15, 2009 | 09:47 PM
fnx4wheeler
Thanks for the help, that clears it up. Is install a pain?
Old Jul 15, 2009 | 10:00 PM
  #28
clux's Avatar
clux
Moving the battery is a bitch. The rest isn't too bad.
Old Jul 16, 2009 | 08:53 AM
  #29
rebelchevy02
This isnt too terrible if you can get the 6oh battery tray.
Old Jul 16, 2009 | 09:06 AM
  #30
superduty4x4's Avatar
superduty4x4
Did you need a new positive batt cable or did yours reach?
