FTE vin decoder info error
Old Jul 6, 2009 | 09:09 PM
peganit2's Avatar
peganit2
I punched the VIN from the frame on what surely looks like a "highboy", (narrow frame, divorced 203 transfer case, ram assist power steering, 4 inch spacer blocks in the rear spring pack) into the FTE vin decoder and it outputed that it was a 78 F250 4wd, engine unknown.
The vin is F26YLBO6757. All prior info tells me that it is a 73-77.5 truck. What gives?
Old Jul 6, 2009 | 09:10 PM
76f350spercamprspeal's Avatar
I wouldn't trust that Vin Decoder....
OK,I decoded your VIN,If I am wrong,Someone will correct me.
VIN#: F26YLBO6757
Model Year: '78
Series: F-250 - 4x4 Pickup
Engine: V-8, 360ci-2-Barrel
Assembly Plant: Michigan Truck
Old Jul 6, 2009 | 09:20 PM
peganit2's Avatar
peganit2
Appreciate it.
Old Jul 6, 2009 | 10:48 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
VIN#: F26YLBO6757
Model Year: '78
No 360s after 1976...
The O you have is a 0
Vin decodes as a 1976 F250 4WD Pickup built at the Michigan Truck plant in December 1975 and powered by a 8 cyl 360 cid 2-bbl engine.
Old Jul 6, 2009 | 10:51 PM
Jermafenser's Avatar
Jermafenser
VIN#: F26YLBO6757
Model Year: '78
How many times have you been told this? Unless you know all the correct info, don't decode anything!
Bullitt is correct, the letter "O" is incorrect. The letter "O" never appeared on the 7th digit. It should be the number zero, "0".
Old Jul 6, 2009 | 10:55 PM
OK,Here is the correct one:
VIN#: F26YLB06757
Model Year: '76
Engine: V-8, 360ci, 2-Barrel
Old Jul 7, 2009 | 12:20 AM
peganit2's Avatar
peganit2
Thanks guys.
The 0 vs O is my fault. I had that question in my mind whether it was a letter or a number and I chose letter because I have another vin number that has an unmistakable "C" in the seventh spot so assumed that they all were letters.
Anyway, thanks again, it clears up a lot of confusion with my truck.
Zbillgee
Aftermarket Products
Apr 28, 2016 04:28 PM
Will237
1947 and Older Ford Trucks
Apr 4, 2016 12:35 PM
badassgixxer100
Dec 10, 2015 09:06 PM
ocastari
Oct 5, 2012 10:55 PM
Aaron-71
May 17, 2011 02:17 PM
