leveling kit question
Old Jul 6, 2009 | 03:11 PM
mike242424's Avatar
mike242424
I'm interested in getting a leveling kit for my 96 f-150 with coil springs in the front. I'd like to get a good kit and was wondering if anyone had some good advice as in what exactly to get. It is 4 wheel by the way. Also is this a difficult job? thanks alot
Mike
Old Jul 6, 2009 | 03:36 PM
1966Tbird's Avatar
1966Tbird
it's not hard at all i just used spacers and i take my truck off jumps time to time hardest part is getting shocks if you have a quad shock front end as long as the spacers are polyurathane and they have the stud extentions your good
or you could get an expensive one from bds and have the same results
Old Jul 6, 2009 | 04:41 PM
nnewman's Avatar
nnewman
I used Superlift 2" leveling coils. They're only $135 for a pair. They came with camber adjustment bushings. The bushings are "adjustable"; they can correct different amounts of camber, but they'll affect caster at the same time. I'd let the alignment shop buy the bushings after they check it to see exactly what correction needs to be made. The coils were extremely simple to put in.
Old Jul 6, 2009 | 09:15 PM
mike242424's Avatar
mike242424
thanks for the advice. Where is a good place to get those 2 inch leveling coils?
Old Jul 7, 2009 | 03:02 PM
mike242424's Avatar
mike242424
also do you need and alignment after putting new springs in? What about the polyurethane spacers? thanks
Old Jul 7, 2009 | 03:05 PM
17fordguy's Avatar
17fordguy
yes u should get an alighnment after doing eather i personaly would go with the springs.
Old Jul 7, 2009 | 03:33 PM
mike242424's Avatar
mike242424
yeah that makes sense thanks for the feedback. I'm hearing putting springs in is an easy job. I've never worked with coil springs before. Is there any special tools or methods i should know about?
Old Jul 7, 2009 | 03:48 PM
17fordguy's Avatar
17fordguy
every truck i have done springs or spacers on ive always needed a spring compressor but i never did one on these trucks so not 100% shure.
Old Jul 7, 2009 | 05:56 PM
nnewman's Avatar
nnewman
I got mine at Jeff's Bronco Graveyard, but I haven't compared prices lately. You will need an alignment after the lift. It's definitely drivable, but you'll wear the outsides of your tires pretty badly. If you go with the springs you don't need any spacers. No special tools are needed. You don't have to compress these springs to get them out; just jack the truck up by the frame (not the axle) & they'll unload, then remove a couple of retainers & the come right out.
Old Jul 7, 2009 | 07:29 PM
mike242424's Avatar
mike242424
thanks for all the info guys . I'm gonna go with the springs definately. And maybe depending on how its sitting an add a leaf in the back
Old Jul 8, 2009 | 10:32 AM
mike242424's Avatar
mike242424
so i know i said i was getting springs but a buddy of mine talked me into the spacer. I ordered the daystar 2 inch polyurethane spacers. Anyone have these or have anything good to say. If Anyone has something bad to say i'd like to hear as well. Thanks
Old Jul 8, 2009 | 10:46 AM
17fordguy's Avatar
17fordguy
installed these on an 05 guy beat the crap out of the truck but never had a problem with them.
Old Jul 8, 2009 | 01:04 PM
BuickBrian's Avatar
BuickBrian
Post some pictures when you are done with it--I am considering doing this to my '88 F150 4x4 short bed and am curious how it will look when it is done.
Old Jul 8, 2009 | 01:07 PM
mike242424's Avatar
mike242424
Thumbs up
well thats good to know
Old Jul 8, 2009 | 01:08 PM
mike242424's Avatar
mike242424
ok yeah i will i may mor may not do an add aleaf in the back but i will let you know
