54 Door Window installation help
Old Jul 6, 2009 | 01:49 PM
medicpg's Avatar
medicpg
Just started installing the New Glass in the doors of my 1954 F100 and I am having some trouble getting the glass to go up and down smoothly.
I didn't see anything Binding, I am going to closely look tonite, but I was wondering if anyone had idea's or knew of any known issues in getting the glass to move slowly
Old Jul 6, 2009 | 02:07 PM
jaye's Avatar
jaye
Did you put in new window runners/felts check to ensure you don't have a rivet in the channel, also check the window mechanism to make sure it operates smoothly without the glass attached, put some grease on the teeth and on the crank handle teeth and any other location where there's a rivet that pivots. Also make sure your windoe channel isn't bent.
Old Jul 6, 2009 | 03:08 PM
sjahnke's Avatar
sjahnke
I had the same problem on my 53 when I installed new window felts to replace the disintegrated old ones. It seems the doors had been slammed shut so many times that the window opening in the door had closed up and I had to use wedges to open it back up. I hope yours is a simpler fix.
Old Jul 6, 2009 | 07:57 PM
53pickemuptruck's Avatar
53pickemuptruck
Try loosening the screws that hold the channels on the side of the door and move them in or out while rolling the window up and down. The channels fit tight on new felts.
bigf350sd
1947 and Older Ford Trucks
18
Oct 22, 2022 05:28 AM
ssg1957
Jul 2, 2015 06:40 PM
Juddpease
Sep 10, 2014 04:33 PM
Corpsman24
Jun 24, 2013 11:06 AM
51truck
Sep 20, 2003 04:44 PM
