HD Tow package
Old Jul 6, 2009 | 10:16 AM
samw57's Avatar
samw57
Post HD Tow package
I have an 02 Excursion with 7.3L PSD, got it from the dealer (used). I tow a 22' camper and some misc. equipment around and the Excursion OEM dealer sticker says it has HD tow package? I bought a brake controller for it but could not find the port to plug it in. I take it I do not need a brake controller for a my Excursion? A pre-installed HD tow packge is new to me. Any advice/.tips is appreciated.
Old Jul 6, 2009 | 10:30 AM
X-70STANG-F150's Avatar
X-70STANG-F150
There probably is not a "plug" for the brake controller, but you are probably pre-wired for one. There should be a group of tagged wires under the dash behind the OBD port (lower right of the steering column). You can wire the controller directly to these wires. With some controllers you can purchase the plugs seperately so that you can remove the controller easilly when not in use.
You should check the specs for the weight of your camper to determine if you need a brake controller, weight distributing hitch, etc.
Old Jul 6, 2009 | 11:06 AM
gr8scott72's Avatar
gr8scott72
No, there IS a plug for a brake controller. When you get a brake controller, you can get it with a model specific harness. That harness will plug directly into the plug under the dash in the Excursion. It's under there, keep looking. It has 4 wires. There was a thread on here recently telling where to look. I was able to find mine without much trouble.
Btw, get a Tekonsha Prodigy brake controller. They're the best.
Oh, and some states require trailer brakes for any trailer over even 2,000 lbs.
Old Jul 6, 2009 | 11:44 AM
Cardiac69's Avatar
Cardiac69
Yep, as Scott said, there is a plug under the dash. Pull your large access panel off and it is on the other side of one of the metal support brackets, almost inline with the radio. It is difficult to find...
Old Jul 6, 2009 | 11:49 AM
samw57's Avatar
samw57
I looked under the dash because I put one on my 98 Expedition I had, but I could not find the plug on this one. I will keep looking for it! Scott, If you find that thread, let me know. Thanks guys!
Old Jul 6, 2009 | 12:09 PM
gr8scott72's Avatar
gr8scott72
Search is your friend. I searched "brake controller" and this was on the first page of results.
https://www.ford-trucks.com/forums/8...r-install.html
Old Jul 6, 2009 | 03:08 PM
aklim's Avatar
aklim
https://www.ford-trucks.com/forums/s...46&postcount=8
Old Jul 7, 2009 | 01:55 AM
wallz's Avatar
wallz
The tow package added the towing mirrors the rear anti sway bar and the wiring for the brake controller. Actually I think all the X's where wired for that. That said, I would check in the back and see if you do have the anti sway bar.
Old Jul 7, 2009 | 06:49 AM
samw57's Avatar
samw57
I looked last night under the knee blocker panel and found the plug in that little triangle hole under the radio. thanks guys!
wallz - if my memory serves me right, i don't believe i have a rear anti sway bar.
Old Jul 8, 2009 | 08:13 PM
wallz's Avatar
wallz
Did you atleast get the tow mirrors? If you didn't, I would be very hard pressed to say that you got the tow package on that one. Even tho the dealer may say it.
Old Jul 9, 2009 | 01:36 PM
samw57's Avatar
samw57
Yes, I have the heated tow mirrors at least.
how much do rear sway bars really help?
Old Jul 9, 2009 | 02:38 PM
X_Hemi_Guy's Avatar
X_Hemi_Guy
IMO a vehicle with this high a center of gravity should not have left the factory without one...for your smaller camper...you don't need one...but for the Ex by itself...I'd recommend one...it really does reduce the body roll in corners.
You can get a Hellwig delivered to your door for around $200...about an hour of your time to install and it is done...you won't be disappointed in the performance.
Good luck and a somewhat belated welcome to FTE!!!
Joe.
Old Jul 10, 2009 | 08:17 PM
wallz's Avatar
wallz
Like Joe says, I would recommend one. When I purchased the X there was no sway bar. I replaced my shocks and added the rear sway at the same time, and wow, what a difference. The body roll was noticably less.
Old Jul 12, 2009 | 01:42 PM
Paul Hicks's Avatar
Paul Hicks
New Excursion
I am the proud new owner of a 2004 Excursion Eddie Bower edition. I am also having trouble finding the plug for the brake controller. I seen a set of wires that look like they have been cut colors are (Red, White, Blue and 3 Black wires). I am still looking, but any more help would be great.
Old Jul 12, 2009 | 09:34 PM
aklim's Avatar
aklim
Where are you seeing these wires? In the engine bay? That is totally different.
