Front end bushings?
Old Jul 5, 2009 | 11:52 PM
crazymut's Avatar
crazymut
Front end bushings?
I have 141k on my truck and was wandering if I should be expecting to replace my front end bushings soon. Also my cab to frame mount bushings are going south, how big of a job is that? The ones right below your feet in the cab. Has anyone used Revtek leveling kits? Are you happy with them?
Old Jul 6, 2009 | 07:00 AM
Visseroth's Avatar
Visseroth
Well usually the bushings will let you know when they fail but you can inspect them. If they are severely cracked then they are close to going bad but you still may get a couple years out of them. If they are loose then it's time to replace them.
In regards to your other questions........... BUMP.
