Transmission Cooling Lines???
Old Jul 10, 2001 | 03:54 AM
trannyhell's Avatar
trannyhell
This is for a Ford 150 93' - E4OD Tranny Recently rebuilt.
I was told that I could use rubber hydralic hoses to replace the old metal hoses that have been bent and twisted.
Also, If so would bigger hoses be better to run?
AND, If one was to add another cooler what would be the best place? How do I run the lines???
EX.:
1. From tranny > new extra Cooler > Original Cooler > Tranny?
2. From tranny > Original Cooler > New Extra Cooler > Tranny??
Old Jul 15, 2001 | 11:22 AM
larry derouin's Avatar
larry derouin
OPTION #2.
Steel tubing can be bent with use of a tubing bender (looks like a handle with a 3-4 groove wheel on the end and an arm. Bend as necessary to clear with as wide a berth as possible all heat sources(exhaust pipes, cats, etc.)
You can use hydraulic hose from the factory cooler to the aftermarket cooler. DOUBLE CLAMP all connections if you do this. otherwise use steel tubing.
Close quarters thru the radiator support wall (fascia??) split a section of heater hose and layer it over the hydraulic line (this will allow the heater hose to take the vibration chaffing instead of the hydraulic line)or steel tubing.
install the aftermarket cooler out front.
Hope this helps.
Larry
Old Jul 18, 2001 | 12:42 AM
trannyhell's Avatar
trannyhell
Thanks! I just had tranny rebuilt again and it works perfectly... New lines were installed and the internal stock cooler was cleaned/flushed out... Now all I need is an aftermarket cooler? Does anyone have any suggestions.. I would like to have an temp and pressure guage on the line if at all possible??? Anyone know of a good kit with it all??
Old Jul 18, 2001 | 10:56 AM
larry derouin
Haynes and Trans-cool make decent coolers.
Get a plate cooler. Tube and fin for same rating are much larger and with the amount of room the factory leaves between the grill and the A/C unit, your gonna need a physically smaller unit.
Figure out what your hauling (weight wise, GROSS COMBINED VEHICLE WEIGHT, and multiple by 1.5-2.0)this will give you weight rating range to work with. Personally I have always gone with 20-25,000 GCVWR coolers and never had a failure due to heat in towing for 31 years. None of the rigs (mine and Dad's) I've driven have grossed over 12,000#.
Go to local speed shop and tell them what your looking for. They should be able to work something up for you, as far as gauges are concerned.
Old Jul 18, 2001 | 02:43 PM
whittey's Avatar
whittey
jayjordon
Nov 19, 2016 05:11 PM
Volcom
Aug 1, 2015 07:24 PM
LTCPipkin
Aerostar
Mar 12, 2007 08:00 AM
packlet
All Things Towing
Jun 17, 2006 10:57 AM
dakota joe
26
Jun 10, 2006 02:58 PM
