C-6
Old Jul 17, 2001 | 06:58 PM
jkt's Avatar
jkt
C-6
The recommended Tranny fluid stated in the owners manual is no longer aviliable, so what Fluid do i use (D/M III), It is a C-6 tranny out of a 1979 Bronco W/A 400ci? the only thing i can find is 13.335 quarts but that is for a F-150,Does that sound right?
Thank You
P.S I will not be filling the T/C.
Old Jul 18, 2001 | 09:39 PM
Fordtruxrok's Avatar
Fordtruxrok
C-6
the 13 qts is the cap when the trans is totally empty, if you are not draining the convertor than it won't take 13.whatever quarts. It would however be a total waste of time not to drain the convertor since you will be leaving half of the old fluid in there. Type f and Mercon/dexron III are basically the same except m/d III has an antifaomer additive.
Hope this helps!!!!
John
Old Jul 18, 2001 | 09:47 PM
Fordtruxrok
C-6
