Sponsored by: Auxito
Intermitant maf fault
Old Jul 5, 2009 | 07:21 PM
79CAMO's Avatar
79CAMO
Question Intermitant maf fault
99 F-150 5.4. Bought this truck 3 weeks ago, runs great except once in a while it will miss 1 time pretty hard while driving. watching the scanner when this happens i noticed the maf voltage was zero. i backprobed the harness at the connector and i still get a reading, which seems correct, however the scanner still shows zero. what are the odds that i have an intermittant problem with the ecm?
Old Jul 5, 2009 | 09:33 PM
torkum's Avatar
torkum
Can you try another scanner? If the DVM is reading ok I woud question what the scanner is picking up on. Might try disconnecting the battery for a few minutes and see if that changes anything.
Old Jul 7, 2009 | 10:49 AM
79CAMO's Avatar
79CAMO
I believe the scanner is not at fault because i will show a normal maf reading untill the truck misses. then the scanner shows zero for maf reading. as i continue driving the maf reading will return. i cannot find a pattern to the issue either.
Old Jul 7, 2009 | 06:33 PM
projectSHO89's Avatar
projectSHO89
I'd lay my odds on an intermittent wire harness or connector.
Old Jul 10, 2009 | 10:16 AM
79CAMO's Avatar
79CAMO
I think I found the problem. I checked the plug going into the ecm and found that if i tried to twist it a little the maf voltage would zero out. if i loosened the bolt about two turns which pulls the plug out a little I cannot make it loose connection. I have drove two days with the plug a little loose and havent had anymore trouble. now i think i will try to put some dielectric grease on it and tighten it back up.
Old Jul 10, 2009 | 04:51 PM
bada$$f150's Avatar
bada$$f150
Id spray some electronics cleaner in there first, let it sit for a little, then the dielectric grease.
SoCar72
Aug 8, 2012 07:07 PM
tallahassee bronco
1978 - 1996 Big Bronco
May 25, 2012 04:37 PM
bob j
1997 - 2003 F150
Jan 6, 2007 08:14 PM
wptski
1983 - 2012 Ranger & B-Series
29
Sep 3, 2002 11:13 PM
