Will this tire fit?
Old Jul 4, 2009 | 07:04 PM
Jeremy2788's Avatar
Jeremy2788
Will this tire fit?
Sorry, I am really bad with tire sizes and such...
But, will this fit on my truck? LT285/70R17, the total diameter is 32.76 inches. I have a 4x2 with a 2 inch level kit. And more importantly do you think that those will fit with the stock rims? Because while I would like to get new rims eventually, i can't really afford them at the moment.
Thanks!
Old Jul 4, 2009 | 09:39 PM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
You can fit a 32" tire on a 4x2 just fine.
and the 285 width is only maybe 1" wider than stock...so it would be safe on the 7.5" wide rims you have right now.
The size you want however are going to be pushing it. that is almost 33" tall...which leads to rubbage on a stock 4x2.
have you looked at a 265/70/17? that is 32" tall...and would give you 0 issues.
the 285/70/17 you want is basically going to require a leveling kit...or some very selective cutting inside the fenderwell
Old Jul 5, 2009 | 12:17 AM
daoudw's Avatar
daoudw
Hey there,
I have been driving around with 285/70/R17 (Cooper Discoverer STT) for more than two years, including some heavy duty off road (sand and rocks), and I have never had any issues with rubbing. I have a 4x4 2005 Ford F-150 Lariat, and now the same tires on the 2009 F-150 FX, and that is fine too.
Old Jul 5, 2009 | 01:43 AM
Jeremy2788's Avatar
Jeremy2788
Well I have a level kit installed on the truck, so a 33 should fit?
Thank you both for your input.
Old Jul 5, 2009 | 04:05 AM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
sorry, missed that you have the leveling kit installed
yes. You are good to go. Have fun and post some pictures of the final setup
Old Jul 5, 2009 | 03:43 PM
Jeremy2788's Avatar
Jeremy2788
Sweet, thanks for the help. When i finally purchase them I will definitely post pictures.
Shwan_89HD
34
Apr 1, 2015 07:16 AM
chadillac80
Jan 12, 2014 04:57 PM
rtazz17
Sep 26, 2009 06:30 PM
Scoop531
Apr 9, 2007 02:13 PM
78CREW
Oct 26, 2002 09:49 PM
