2005 F150 floor mat needed
I have Catch-alls in my 2007, and love them. Check the link.
http://www.autoanything.com/floor-ma...1455A0A0A.aspx
There are lots of aftermarket products.
If you want a Ford product:
1. Look on the mat for a part number. That way you only have to replace one side. However, it will probably cost as much as a full set.
2. Look in the Ford accessories web page, although it looks like they only have the all-weather mats, not the carpeted ones.
3. Contact your friendly local junkyard.
Unless you are doing something like replacing someone else's that you damaged, an aftermarket replacement is probably the simplest choice.
Good luck,
Good luck,
