Which C6 transmission
Old Aug 4, 2001 | 08:46 AM
bigjoeroy's Avatar
bigjoeroy
I have a '78 4x4 with 460/C6/NP205.
I need to know if I have the 7" or 10" output shaft.
How can I tell?
thanks
Joe
Old Aug 5, 2001 | 07:48 AM
Nathan's Avatar
Nathan
You should measure the adapter between the tranny and transfer case. If I remember right, one is about 6" and one about 9". I know that an F250 long bed (my brothers) has the long one and F150 short bed (mine) has the short one. The 250 has a Dana 60 front, 150 has 44 front. Not sure which aspect needs which length shaft.
Nathan
Old Aug 6, 2001 | 08:11 PM
Steve_Uzi's Avatar
Steve_Uzi
[font size="1" color="#FF0000"]LAST EDITED ON 06-Aug-01 AT 09:18 PM (EST)[/font][p]Actually I believe the Correct lengths of shafts out of a 4WD C-6 Are 5 inches and 8 inches. 5 inch ones were usually found in Bronco's and Short F-150s, 8 inch shafts usually found in LWB F-series trucks.
Uzi... Yamaha Sleds, Honda Bikes, and Ford Trucks....
Old Aug 7, 2001 | 08:31 AM
bigjoeroy's Avatar
bigjoeroy
The truck is a '78 long bed. Where do you measure from, just the visible part of the shaft or from the edge of the transmission case to the end of the shaft?
thanks
Joe
Old Aug 7, 2001 | 03:47 PM
crazy_goodolboy's Avatar
crazy_goodolboy
