Sponsored by: Auxito
Door window problems
Old Jul 3, 2009 | 02:17 AM
xFordx78's Avatar
xFordx78
Ok I have a 1997 ford f-150 XL extended cab and the passanger side door window will not roll up without some help which is really annoying.So I removed the door panel and looked inside and the big metal thing that rolls the window up has some teeth that are worn and broke off causeing it not to roll up when it gets to a certain point can anyone tell me what this part is called so I can know what I need to buy to fix it and how hard it is to fix? these are manual windows no pwer.Thanks hope someone can help
Old Jul 3, 2009 | 02:59 AM
xFordx78's Avatar
xFordx78
Looks more like a flywheel the about 5 teeth are broke preventing window from functioning just dont know anything about replacing that part or what it is called.
Old Jul 3, 2009 | 05:52 AM
ncranchero's Avatar
ncranchero
It's called a window regulator.
http://cgi.ebay.com/ebaymotors/97-98...%3A1|72%3A1171
Old Jul 3, 2009 | 11:35 AM
xFordx78's Avatar
xFordx78
I dont think that is it that part looks like what takes the window up and down.The part I need looks like a big flywheel with teeth like a sprocket the teeth are broken.
Old Jul 4, 2009 | 02:18 PM
xFordx78's Avatar
xFordx78
Nobody knows what that flywheel looking object inside the window is called or how to fix it?
Old Jul 4, 2009 | 03:03 PM
ncranchero's Avatar
ncranchero
Originally Posted by xFordx78
Ok I have a 1997 ford f-150 XL extended cab and the passenger side door window will not roll up without some help which is really annoying.So I removed the door panel and looked inside and the big metal thing that rolls the window up has some teeth that are worn and broke off causing it not to roll up when it gets to a certain point can anyone tell me what this part is called so I can know what I need to buy to fix it and how hard it is to fix? these are manual windows no power.Thanks hope someone can help
The photo in the link may not appear to be the same thing but the "thing" with "teeth" that looks like a "flywheel" , or should look like half of a flywheel, IS called a window regulator.
It will require drilling out 3 rivets, 1/4" dia. rivets, and you'll have to have access to a large rivet gun capable of replacing those 1/4" rivets. If you don't have or can't borrow a rivet gun of that size it would be best to see what a shop will charge to replace the WINDOW REGULATOR. Those rivet guns are well over $100.00 .
Old Jul 4, 2009 | 03:57 PM
xFordx78's Avatar
xFordx78
Ahh so the big fly wheel looking thingy with the teeth is in fact a window regulator ok thanks a lot I will see how much a shop will charge.
Old Jul 4, 2009 | 07:28 PM
westtexastiger's Avatar
westtexastiger
I thought that whole assembly was referred to as the window regulator, not just your part that the plastic teeth sheered off of. Sounds like what happened to an '02 Grand Am SE I used to own. I only had the car for three years, but I replaced the driver's side front window regulator FOUR *bleep*ing times. Replaced the passenger side from once, too.
Old Jul 8, 2009 | 11:28 AM
1Aauto's Avatar
1Aauto
Former Vendor
The teeth part and the arm is usually sold as a whole assembly. I just checked our site for you.I don't have one for this application.We carry a pile of these things too.
If you have anymore questions,feel free to pick our brains.
