Need help
Old Jul 2, 2009 | 08:58 PM
msurness's Avatar
msurness
Need help
I have a '96 powerstroke. Trying to change the high pressure oil pump. Need to remove the fuel filter housing to get the high pressure oil pump off. Have removed everything i can see, but the fuel filter housing don't want to come off. Any sugestions?
Old Jul 2, 2009 | 10:15 PM
kawa's Avatar
kawa
Tell us more. Does the filter housing move, wiggle from side to side, what does it do or don't do? ( other than part itself from the engine)
Rog
Old Jul 3, 2009 | 10:18 AM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
This may help you (part of the write up from Sam Miller)
Draining the fuel filter/water separator canister. You will want to either place a container under the vehicle to catch the diesel (a hose pushed on to the drain tube sure prevents a mess), or pump the canister dry once you get the filter out, in which case you won’t slide the yellow lever to "DRAIN." This is a good occasion to inspect and clean the interior of the canister, so removal of the filter and heater is advised. (Remember, the plastic heater standpipe is LEFT HAND THREADS.) A 7/8" crow’s foot wrench works best, but I have loosened it with a regular open-end wrench. Pull off the heater wire connector with needle-nose pliers. Now you can clean the canister and check for cracks or leaks. You’ll be amazed at the crud in there.
Disconnecting hoses. There are two hoses connected to the top of the pump and one at the bottom. The two top hoses are protected by a removable clip-on heat shield (just yank it off). You can only get to the clamp on the pump side of that bottom hose. And finally, the water drain hose at the front passenger side of the filter housing.
Remove the two bolts attaching the fuel pressure regulator with 10mm and carefully pry it back from the filter housing, taking care not to lose the O-ring. Good time to clean the screen and examine condition of O-ring. There is also a short section of 5/16" hose that may need to be replaced.
Separate the wire harness connector on the passenger side of canister and remove positioning clamp with 8mm. It will NOT slide off the tongue of the clamp as you think it might, since the tongue is barbed. (Remind you of anyone?)
Disconnect wires connected to the canister, two on drivers side, one at bottom rear. (So now you want to know what they are? Aw geez, you’re one of THOSE GUYS: Oh, all right: on the driver’s side, the top connector on the side of the Water Filter/Water Separator Assembly is the fuel heater connection; the connector directly beneath it links to the Water Sensor; and the connector on the bottom rear of the Assembly is for the filter restriction sensor. I believe it is a vacuum switch. Note: In 1996 the fuel filter restriction sensor was moved to the fuel pressure regulator, driver’s side of filter housing. Happy now?)
To continue: Two bolts holding down the filter canister are 13mm. You can lift the whole filter assembly up and forward out of the way with the long blue hose still connected at the bottom
Old Jul 3, 2009 | 10:19 AM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
BTW, welcome to the forum and good luck.
Old Jul 3, 2009 | 10:41 AM
msurness's Avatar
msurness
Yes the housing moves side to side front to back. It even lifts up just a little. I took the filter out to see if i could see anything inside holding it down, but didn't see anything.
Old Jul 3, 2009 | 10:58 AM
Cuda_jim's Avatar
Cuda_jim
If the canister is loose then the small blue rubber hoses going to the fuel pump are holding it. There may be a heat shield over them. Pry it off then cut them & replace. The are a source for leaks. Use any Fuel injected rated hoses compatible with diesel.
Here's a picture with the heat shield removed.
Old Jul 3, 2009 | 11:03 AM
msurness's Avatar
msurness
Thanks for all the good detailed info. Can't wait to get off work so i can fix my truck. Sucks not driving it!
hank89
May 13, 2013 04:05 PM
HORN X 4
Jan 10, 2013 06:55 PM
Primosf150
Dec 5, 2011 07:53 PM
racenitro
24
Mar 30, 2007 10:12 AM
