Free MPGs, sort of
Old Jul 2, 2009 | 08:44 AM
mueckster's Avatar
mueckster
Free MPGs, sort of
I had recalibrated my speedometer a while back and though it was reading accurately. I recently bought a GPS navigation system and found the speedometer was showing 'higher' that my actual speed on the GPS. By calibrating it to correct speed, I will gain a little more on my odometer reading and therefore raise my MPG's. I thought I was doing pretty good MPG wise, but now I feel a little more better about it. I had discussed this with Chris (F350-6) and wanted to share the info.
Old Jul 2, 2009 | 08:57 AM
Justin03PSD's Avatar
Justin03PSD
What size tires do you run?
Old Jul 2, 2009 | 08:59 AM
DieselCamper01's Avatar
DieselCamper01
That IS good news. Congrats Roland.
Old Jul 2, 2009 | 09:08 AM
mueckster's Avatar
mueckster
I'm running 285's.
I used the tire height spec from a website to enter in the calibration formula, but found the actual size was different. This was affecting the speedometer recalibration and causing it to show to more that my actual speed. I used a Hypertech Speedometer Calibrator before I got the AE.
Old Jul 2, 2009 | 09:16 AM
riverrat41's Avatar
riverrat41
I need to get with Chris(F350-6) and do this to mine as well.Maybe after I get new boots(tires)
Old Jul 2, 2009 | 09:24 AM
Izzy351's Avatar
Izzy351
Yep -- mine is reads fast as well. But wouldn't that show MORE miles on the same amount of fuel? If you set it so it shows a slower speed, you'll be covering fewer miles, at least on the odometer, so you'll actually get fewer MPGs. Or do I have this back-asswards somehow?
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Roland, bring your GPS with you. lol. We can check mine. I could use more MPG. Congrats on the recal.
Old Jul 2, 2009 | 09:35 AM
miller_feed
I think you are right Joe.
Old Jul 2, 2009 | 09:46 AM
mueckster's Avatar
mueckster
I get more confused the more I try to think about this. I may have shot myself in the foot with my statement. I do know that I have I it reading correctly now and it seems like I have traveled more miles, by my fuel gauge, than I usually get since I filled up a couple of days ago. I played with the tire size to finally get it to read right. I went both ways and rechecked the speed.
Oh well, at least I know that it's right now.
Old Jul 2, 2009 | 09:55 AM
spdmpo's Avatar
spdmpo
Yes, it is backwards from what you originally thought. If your speedo is reading high, then the odometer shows you are traveling farther than you really are. So you're mileage will actually not be as good as you thought. Doh! Can you go back and forget what you've found?
Old Jul 2, 2009 | 09:58 AM
big poppa's Avatar
big poppa
With my GPS and running 285's, my MPH on both seem good but I'll look a little closer, nice writeup Roland..on the GPS calibration.
Old Jul 2, 2009 | 10:08 AM
mueckster's Avatar
mueckster
It wasn't by much. I just like things to be right. I feel like such a fool.
Files deleted in my memory banks. It sounded good anyway.
Old Jul 2, 2009 | 10:21 AM
spdmpo's Avatar
spdmpo
When I first bought my truck it had 35s on it. I was thinking the same thing about the mileage, that it was better than I was getting. When I put the shorter 285s on there, I realized I had it backwards. Don't really care anymore now, I just fill it up when it's empty. It is what it is. I did an experiment last weekend and calculated the mileage, but it's rare I do that.
Old Jul 2, 2009 | 10:36 AM
mueckster's Avatar
mueckster
I check my mileage every tank. My says to "let it be". I really need to start listening to her.
Old Jul 2, 2009 | 10:43 AM
fifthwheel01's Avatar
fifthwheel01
When I bought my truck for the first 6months I was getting a constant 20 mpg....
Till I read that the overhead digital computer is
A.K.A. --- LIE O METER
