Sponsored by: Real Truck
Need help with ground loop please.
Old Jul 1, 2009 | 08:34 PM
System's Avatar
System
Prolocutor
I posted this in the audio section, but after looking at how often it get's visited, I figured I'd get more views and help here. I just added a Bazooka amplified tube to my stock audiophile system with factory sub. The factory sub helped, but really wasn't nearly enough and the stereo sounded tinny. I'm not really a fan of Bazooka, but the 6.5 unit fit right under the back seat with no issue. I didn't want to loose my console or floor space, so it was my only option. So, I use the factory sub's line in as a source for the tube. Wire everything up and man, is it perfect. Unplug either of the two subs and it's just not the same. They each produce a completely different base type and compliment each other perfectly. Now for the issue. Key off, no problems. Key in the run position, whine from the factory sub. Start the engine and with the volume low or off, a good old fashioned ground loop that fluctuates with the idle. I've tried everything. Different grounding locations. Different power locations. Different remote turn on source. Nothing changes. Unplug the line feed to the Bazooka and the whine stops. I did try an old Radio Shack ground loop isolator which completely eliminated the problem, but also eliminated 50-75% of the bass output of the Bazooka. Not sure why. So, back out it came. Any thoughts on how to solve this?
Old Jul 1, 2009 | 09:11 PM
ReAX's Avatar
ReAX
I'll go answer it in the audio forum.
Old Jul 2, 2009 | 01:16 PM
cartmanea's Avatar
cartmanea
I have the same issue with my 4-channel amp. I've tried it all and the only thing I can think of is its just a cheap amp without power supply isolation.
