Engine barely turns over, need help!
Old Jul 1, 2009 | 12:08 PM
kaduh's Avatar
kaduh
I have a 96 F-150 that I have not started in three years. I put a new battery, terminal connections and had the starter checked out. It just barely turns over when I try to start it. I did notice that the negative lead gets pretty hot after a few turns of the key. I checked and cleaned both positive and negative connections to the starter and block/chassis. Any help or suggestions will be greatly appreciated.
Old Jul 1, 2009 | 12:44 PM
andym's Avatar
andym
Replace the battery cables. In fact, it's a bad idea to just replace the ends without replacing the whole cable.
Old Jul 1, 2009 | 12:46 PM
quicklook2's Avatar
quicklook2
i think that has something to do with it.
oil will be in bad shape.
rust in cylinders is a possibility.
all oil drains/passages may be a bit gummed up.
starter may be rusted up inside.
