on a 1989 f-350 4x4
front and rear axle ratio ,what options were available ?
and having the king pins on the front is it a dana 44 0r 60?
thanks
the engine is a 460 fual injected ,transmission ????4spd 4x4 on the floor
how much are these worth as i will be selling them individually
thanks
do you know about how mush these go for or worth ,they are still on the truck and work great ,and is there any id tags that would help clarify ,or do I tap on it with a hammer
and try to listen for a echo ,
thanks
a solid king pin dana 60 front end runs 1000 dollars without being a rebuilt unit. The dana 50 runs fairly close to scrap metal price. The tapping on it with a hammer is a new one on me not sure what that would get you. Sometimes the dana 44 and dana 60 had the '44' or '60' stamped on the webbing of the pumpkin, but a 44 looks smaller than a 60 and the only solid axle 44 that i know of run on anything close to the 1ton was the 70's 44 HD on a F250s from the factory.
about the dana ,I still do not know what one I have
the #s on the pumpkin read as follows
dana inside diamond
620079
115-8
rev 0
5 26 77
there are 10 bolts ,so from that ,it is a dana 44 ?
also #s below the pumpkin cover
read 620093H on the bottom
and 105 on the top side
the rear diff has 11 bolts ?
thanks
pictures of the front dana ,from what I am told 1g
and the rear diff
transfer case ,what would these other be worth ,seeing that I am selling them
on ebay soon I hope or if someone else would like to buy them
got a price on shipping just the front diff anywhere usa max,$400.
the engine also runs good
let me know if any wants them or how much are the other items worth ,
thanks
