I purchased the bolt remover posted above. Wow, I should have asked for these for my 12th birthday. The bolts came out easier than I could have imagined. Thanks
Are you guys using 6 point sockets? That will help tremendously, anyone that works on old rusty vehicles should have 6 point sockets.
Also, if you are trying to take a 9/16 headed bolt out, sometimes a 6 point 14mm will work. 14mm is very close to a 9/16, but it's just a tad smaller so sometimes it will save you if it's not too bad.
Yep, those things are the best I've seen. The home mix penetrating solution of acetone and trans fluid is the most amazing thing I've used in a while too.
