Sponsored by: Auxito
intake question
Old Jun 30, 2009 | 07:25 PM
firefighter1416's Avatar
firefighter1416
intake question
This is kind of stupid Question but anyways was wondering if there was and "exceptable" amout of dust that could be past the air filter in the intake. I run a K&N and notice there is a little bit of dust on the other side. i do a lot of dirt road driving and in fields, it has never gotton any worse. its not even bad enough that if you rub your finger on it you can;t hardly tell you have wiped any thing off. anyways just curious thanks alot you guys!
Old Jun 30, 2009 | 08:50 PM
steve(ill)'s Avatar
steve(ill)
no, there is not acceptable level. part of the reason the K&N is thought to breath better is becasue it does not filter as good. by design, it will "pass" a little bit of dust thru the filter, unlike the paper filter.
Old Jun 30, 2009 | 09:27 PM
Bear River's Avatar
Bear River
Former ******
The only acceptable level of dust is particles that can get through a paper filter. This is exactly why I do not use a K&N. I used to, fell for the whole "flows better equals more power" trap. I now use the AFE ProDryS, because it filters to the same level as a stock paper filter, but is freer flowing and washable. I have it more for the washable feature. There are other synthetic dry filters too. All of the synthetic elements from the major brands will outperform the K&N in terms of filtering efficiency. The whole purpose of having a filter is to keep stuff out of the engine. If it passes through anyway, you might as well toss it and go back to stock, or find something that works.
