loud noise while acclerating
Old Jun 29, 2009 | 08:55 PM
zman1202's Avatar
zman1202
i Have a 1986 F-250 6.9 liter turbo diesel, when i am accelerating it is a loud noise like a loud exhaust sound but it is not the exhaust, then it will go away if i let off the gas. Please if you know anything please it would be greatly appreciated.
Old Jun 29, 2009 | 10:56 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Do you have a boost gauge?
You may have a leak between the turbo and intake letting the boost escape.
That would sound sorta like a cross between exhaust and an air hose leaking.
Old Jun 29, 2009 | 11:57 PM
rupejosh's Avatar
rupejosh
sound like a turbo issue to me as well.is it a whine or knock or whistle or does it sound like its sucking air or a rappy sound?
Old Jun 30, 2009 | 04:13 AM
Lazy K's Avatar
Lazy K
Engine cooling fan?
Old Jun 30, 2009 | 08:27 AM
zman1202's Avatar
zman1202
no if its he turbo it is screwed up cause i can barley hear the turbo. I am not sure how to check but i am going to record a video and post later thanks
Old Jun 30, 2009 | 11:18 AM
rupejosh's Avatar
rupejosh
Originally Posted by Lazy K
Engine cooling fan?
thats a good idea it could be the fan clutch locked up
Old Jun 30, 2009 | 08:07 PM
Dave Sponaugle
IDI turbos don't make a lot of noise when they are working right.
Without knowing what the boost level is, it could be several things you are hearing.
I lean toward boost because you said only while you are giving it throttle.
Boost is the highest when your throttle is on the floor.
Even though the RPM does not drop when you take your foot off the throttle, as soon as you stop feeding it fuel the boost drops to almost zero.
Old Jul 1, 2009 | 12:21 PM
zman1202's Avatar
zman1202
The Noise is coming from underneath the floor board like near the gas pedal but it doesn't seem like you can hear it from the outside the truck very well to at all
Old Jul 1, 2009 | 09:59 PM
Dave Sponaugle
Is the down pipe still attached to the turbo?
Some of the IDI turbo connections for the downpipe are not that great.
My 093 turbo has a bracket about 1/2 way down the down pipe that holds it in the turbo.
Yes, I have had the bracket come loose and the down pipe fall out of the turbo.
Also there is not much room in there, if the down pipe is hitting the firewall it will make a racket.
Old Jul 2, 2009 | 03:06 AM
rupejosh's Avatar
rupejosh
maybe the crossover pipe is cracked?just throwing it out there.if thats the case im guessing boost is low as well.
