1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
03 Expy - No A/C coming out of front vents
Old 07-14-2009, 07:20 AM
alwaysfords41's Avatar
alwaysfords41
alwaysfords41 is offline
I just got back from vacation and found my own HVAC problem on the way home. I'm guessing vacuum leak, but please chime in. The front controls give me great cold air, but as you start to bring the temp up it doesn't react until you get to 85 at which point it is pumping full heat. No transition in between. It is very repeatable, and doesn't vary in when it happens, always around 85. Rear controls work fine. '03 EB with auto climate.
Old 07-24-2009, 11:08 AM
JCs2004EXPI's Avatar
JCs2004EXPI
JCs2004EXPI is offline
Right on the money alloro & bumparker! I have a 2004 Ford Expedition Eddie Bauer which had the same issue that everyone is describing. Battery acid ate up the thin hoses. $1.78 later for vacuum hoses at Autozone and I'm back to enjoying my cool A/C in this Southern California heat.
Old 08-02-2009, 04:36 PM
v1uhoh's Avatar
v1uhoh
v1uhoh is offline
Thanks for all the info on this!!
A picture is worht a 1000' words. ( i will try to add my images...sorry)
03 exped. no air out of center vents, only defrost. At one point i had intermittent air out of the front vents, then it finally stopped and only blew from the defroster. The hose probably had a leak and recently failed completely. I popped the hood and found it in about 5 secs...thats no kidding!
I placed a kitchen towel behind it so you can see the break in the line.
FYI..that is a brand new battery and removal of the battery will put stress on the line also, perhaps breaking/cracking it slightly!
Part of me would love to take this to the dealer now and see what would happen...what they would charger me for!
Old 08-02-2009, 05:54 PM
v1uhoh's Avatar
v1uhoh
v1uhoh is offline
i thought this fixed it, but it didnt! I found another small crack just upstream of the break in the line. I added a longer splice of rubber tubing and now the system works as advertised!
the fix below...
Old 09-16-2009, 01:53 PM
richardtresko's Avatar
richardtresko
richardtresko is offline
Problems with A/C vents on 2005 Expedition
I just saw this post and I know very little about fixing cars. Here is my problem: Today, my air condition stopped coming out of the front vents and will only come out of the defrost vents. Is this the same problem you are discussing? If so, what do i do about it?
thanks,
Richard
Old 09-16-2009, 02:26 PM
bumparker's Avatar
bumparker
bumparker is offline
Most likely the same problem, there is a vacuum leak somewhere. It may not be in exactly the same place as shown in the picture but that is where I would start. Find and fix the leak and your problem will disappear.
Old 06-21-2010, 08:09 AM
sicksoh's Avatar
sicksoh
sicksoh is offline
the fix below...
What size tubing did you use to fix this problem I have a break in the exact same place as you did. Thank for your help
Old 06-21-2010, 09:07 AM
alloro's Avatar
alloro
alloro is online now
Received 4,211 Likes on 2,453 Posts
He made that post 10 months ago and might not be around anymore. Try clicking his name and sending him a PM. He might get an email notification of the message.
Old 06-21-2010, 03:41 PM
v1uhoh's Avatar
v1uhoh
v1uhoh is offline
Originally Posted by bumparker
You'll need to remove the battery to get to the vacuum canister and replace all the vacuum lines. Check all the lines as the proximity to the battery (acid) tends to degrade them over time. .
Exactly what happened to mine (see above). Acid ate the vac line. Under accleration i would have wierd things happen in the HVAC. A couple of minutes with a Mighty vac tester and i fixed it with a spare piece of tubing.
Funny..Im back on the site here looking for info on the parking sensor ECM..and saw this. I think it is just some standard 1/8th inch vac tubing...get it at autozone.
Old 06-21-2010, 04:53 PM
alloro's Avatar
alloro
Just my luck, you came back just in time to make a liar out of me.
Old 06-27-2010, 03:49 PM
sicksoh's Avatar
sicksoh
sicksoh is offline
Hey everyone still haven't got , mine fixed I have a broken vac line that I have found looks like it is close to the same one as this pic shows mine is kinda up between those two big plugs you see but I can't find where it attaches to no other piece of line or connection that I can find and I can't get the damn picture to upload so hopefully someone can help me out with just this vague description thanks everyone.
Old 06-27-2010, 06:36 PM
sicksoh's Avatar
sicksoh
sicksoh is offline
ok finally got the pics on photo bucket. So here is my problem I hope. Just can't find where it goes.
  #28
Old 06-27-2010, 08:46 PM
00Harleydavidson's Avatar
00Harleydavidson
00Harleydavidson is offline
Great Pics, really helps when people go the extra mile to help us poor Ford folks out
  #29
Old 06-28-2010, 10:40 AM
sicksoh's Avatar
sicksoh
sicksoh is offline
Or does anyone know where I can find a diagram of all the vac lines on a 2003 navigator. I have tried google but no luck thanks.
  #30
Old 06-28-2010, 11:29 AM
sicksoh's Avatar
sicksoh
sicksoh is offline
found it guys just took getting pissed off at the damn thing and yanking on hoses and wires and it popped out. It had just come out of the connection so I just had to slip it back in. Took it out for a test drive and all is working again. Now just to get the 3rd row power seats working ugh.
Quick Reply: 03 Expy - No A/C coming out of front vents
