Sponsored by: Auxito
P0305
Old Jun 29, 2009 | 11:11 AM
brodyhyde's Avatar
brodyhyde
P0305
My 97 f150 5.4L has been missing on one or more cylinders and I can't figure it out. I got the code p0305 which is #5 cylinder misfire. I replaced PCV valve, fuel filter, air filter and spark plug on #5. I tested the coil on 5 and ohms are correct.
Can't figure out what it could be. The truck is missing at all speeds and RPMs and is beginning to drive me crazy. Anyone run into anything like this or have any suggestions?
Old Jun 29, 2009 | 12:35 PM
KingRanchMan02's Avatar
KingRanchMan02
Welcome to FTE brodyhyde! Replace the COP on that cylinder and you should be good to go. Good luck!
Old Jun 29, 2009 | 12:51 PM
Joe Finn's Avatar
Joe Finn
You can try swapping the COP with another cylinder and see if the fault moves.
YYZ
Dec 5, 2014 09:49 AM
WVVan
Nov 20, 2013 04:00 AM
readyrangerette
Jul 8, 2013 04:20 PM
MaRiNeKiLz
2004 - 2008 F150
Aug 9, 2011 07:41 PM
Pipe Burn
1983 - 2012 Ranger & B-Series
15
Jun 29, 2010 12:27 AM
