loss power
Old Jun 28, 2009 | 07:27 PM
big64's Avatar
big64
loss power
i have a 88 f250 with a 302 and 5speed manuel.at first when the motor was cold,when i take off i had to rev up the engine high and let off the clutch slow in order to get going cause it would feel like it was loading up like a bad carburater,then when it got warmed up it was ok. now it has gotton worse. i changed the filter on the frame ,replaced the fuel pressure regulator prior to this happening,and the iac recently.i think the tank has trash in it.could the injectors be dirty or bad?
Old Jun 29, 2009 | 09:37 AM
Lazy K's Avatar
Lazy K
You may have a bad engine coolant temperature sensor. Might be worth seeing if there are any stored trouble codes. Go to fordfuelinjection.com for instructions on codes if you don`t have a code reader.
