Im 800 hundred miles from home at a friends house when I found a vacum line that is broken off of some kind of module next to the vacum manifold located on the left front fender.
Other lines go to brake booster, vacum pump and a couple of smaller lines that go off to god only knows where.
Any clue as to what this module does. Looks like a hockey puck with a 3-wire connector coming out of the side. The vacum line goes in to the center of the flat side of the puck. I need to replace it but i don't know what to ask for.
I'm also having a brake issue and was also wondering if they are connected.
Thanks - I have a 94 IDI turbo K series F350 with OD transmission. Would this vacumm alarm effect anything else in the truck such as the shifting or brakes
