In the process of swapping a 400M for a 460 in my 1979 4x4
Supercab,i need to rebuild the tranny & transfercase also.
I have a choice of doner tranys:
1) the orignal C6
2) C6 from a 1977 1-ton van
3) 1970 Lincoln trany (motor doner) which I assume is a C6,
didn't look yet
4) 1977 400M Marquis C6
I'm aware of the output shaft diffs.Is ther a better C6 or are they all the same?????
1) the orignal C6
didn't look yet
I wouldn't know without opening them up and taking them apart...but I do know that that are major differences in the amount of tourque and HP that some of the early C-6's would handle. The forward (direct) drum will have room for 5 steels and frictions instead of three for the lighter duty gearboxes...this is easy to upgrade if you can find a 5 friction drum to swap.
The next major difference is in the first/reverse large friction/steels that are at the very back of the case, they actually sit in the case, not in a drum. The light duty trannys have three...the heavy duty trannys have 5. Deen
Deen Hylton
Ford F250 460 C-6, K&N, Headers, Dual Exh.,Comp. Cams,Shift Kit
Pioneer CD w/Bose Speakers.
Other Passion: Blown 77 Corvette (Sorry Guys/Gals)
How I can afford to Drive the above: 93 GEO Metro
The C6 was redesigned for better shifts for the 1977 (I think) model year. Thus, I'd avoid the Lincoln C6. What engine was in the 1-ton van? If it was a 460, that might be a good choice.
