4" lift help!
1. do i need to make drop brackets for the radius arms, or will it be fine how it is?
2. do i need new shocks, or can i reuse the old ones?
3. can i make plates to extend the swaybar bracket?
4. if i do a shackle flip and switch the 3" block for a 2", will i need to get new shocks for the rear too?
5. what other things do i have to look out for?
2. Either new shocks or rework the mounts.
3. Sure, or you could cut it and scab a piece into the bar.
4. Same as #2
5. Brake lines, drive shafts, I don't know if the E brake cables will stretch & steering linkage corrections. You will have to do something with the panhard bar.
