1973 3-speed
Old Dec 9, 2000 | 05:38 PM
toddn's Avatar
toddn
1973 3-speed
I have a 3 speed trans with a 240 inline 6. I am going to be changing the engine to a 351C that I am hoping to get around 350 HP out of. Will the 3 speed bolt up and if so will it handle this much power or should I change the transmision too. Thanks in advance.....
Old Dec 10, 2000 | 08:38 PM
billyb's Avatar
billyb
1973 3-speed
change the transmission. if you want the strongest, go with t18 or t19. if you want strong with overdrive get zf.
Old Nov 6, 2001 | 01:20 AM
7855F100's Avatar
7855F100
1973 3-speed
or if you want stronger still go with the np435 i have 1 in my 78 with a 300 6 perfact gear ratios. rear is a 2.75 ratio
Old Nov 7, 2001 | 01:36 PM
Ratsmoker's Avatar
Ratsmoker
1973 3-speed
That 3 speed is a pretty strong tranny. I wouldn't be afraid to hook it up to your motor. My buddy is putting a 400+ HP 351C in front of his. They are not however good for ripping though the gears.
Old Nov 7, 2001 | 06:57 PM
billyb's Avatar
billyb
1973 3-speed
bigern26
Oct 17, 2010 08:23 PM
stangfan78
Aug 30, 2009 03:14 PM
f1barry
Nov 21, 2008 12:58 PM
Old Yblockman
4 Cylinder Engines
Dec 26, 2004 11:57 AM
debestuss
Jul 14, 2004 07:12 PM
