Sponsored by: Real Truck
Leveling kit alignment issue
Old Jun 26, 2009 | 04:49 PM
cees2u's Avatar
cees2u
Hey Guys. I'm new to the whole forum thing, but it really seems to help a lot of people, so I'm gonna give it a shot.
I have a 2004 F250 Powerstroke 2WD. I recently installed a front end leveling kit. Now my local alignment shop says that they cannot align my truck because it doesn't have enough adjustment. Should this be correct? Is there any way to fix the camber on my truck? Any help will be greatly appreciated!
Old Jun 26, 2009 | 05:14 PM
Unc1eJesse's Avatar
Unc1eJesse
You'll probably need an alignment kit. They're like an eccentric bushing... and they don't cost much. check out rock auto, under your vehicle in the suspension tab
Old Jun 26, 2009 | 06:30 PM
cees2u's Avatar
cees2u
Thanks for the tip. Is there any way to tell which angle I will need? Or is it just best to get the adjustable one, and let the shop figure it out?
Old Jun 27, 2009 | 06:14 AM
Unc1eJesse's Avatar
Unc1eJesse
They should be able to tell you better than I. I lifted a 4x4 (solid axle) so I didn't have to get them. But off the top of me head I'd guess the smallest... just a guess. Some part stores carry these locally btw, if you don't want to pay shipping.
Old Jun 27, 2009 | 07:04 PM
Maxium4x4's Avatar
Maxium4x4
Welcome to FTE cees2u, I moved your post to Super Duty for a better response.
Old Jul 14, 2009 | 04:22 PM
cees2u's Avatar
cees2u
Update...
I have taken my truck to 3 different alignment shops now. Two of them wouldn't touch it. The last one tried it with the adjustable cams but it still ended up with about 2.5 degrees too much positive camber. Anyone have any ideas? Anyone know of anybody else that has used this kind of kit?
Old Jul 15, 2009 | 12:35 AM
JKBrad's Avatar
JKBrad
You're going to need drop brackets for the places where your twin I beams mount to the frame.
Do a google search for Ford twin I beam 2WD lifts and you'll find them. A quality kit should have included them.
Old Jul 15, 2009 | 05:07 AM
cees2u's Avatar
cees2u
This kit only had a spacer that went on the bottom of the spring and a stud extender. It was advertised as an extremely easy, and cheap way to level your truck. Guess it was too good to be true.
Old Aug 15, 2009 | 12:21 AM
cees2u's Avatar
cees2u
Finally!!!
I finally got my truck aligned...It cost $275 and the mechanic had to grind on the steering knuckle to make clearance, In retrospect I should have just bought the full lift kit. Only a little more money, and a LOT better value over all...Oh well...Live and learn.
Old Aug 16, 2009 | 09:02 AM
Unc1eJesse's Avatar
Unc1eJesse
Glad to hear you finally got it fixed. I went cheap first then started throwing the junk out of the kit. A year latter it's still lifted but none of that cheap leveling kit is still on there. The marketing got our money again.
Old Aug 18, 2009 | 01:26 PM
AlignmentGuy's Avatar
AlignmentGuy
The main issue with raising the 2wd is the lack of camber adjustment. Grinding the steering knuckle is not a good idea. Even then you usually dont have enough adjusment left to resolve driveability issues. Dropping the the ibeams at the bracket solves the camber issue but creates the dreaded death wobble and bump steer. Then you get into drop pitman arms that work loose and kill steering gears.....
Hate to be so negative but in all the years i have been working on and specializing in ford front ends I have yet to see a "good" way to raise the front of a twin ibeam truck.
Last edited by Carlene; Aug 18, 2009 at 01:43 PM. Reason: Editted out Advertising part
dsbyrd918
Feb 26, 2015 08:18 AM
vfrf2
Mar 20, 2011 01:59 PM
PKJ
Sep 29, 2010 07:48 AM
zach_barrow
Nov 23, 2004 11:25 AM
jdmclemore
2004 - 2008 F150
Sep 14, 2004 07:22 AM
