Engine sputtering/dieing
Old Jun 25, 2009 | 08:33 PM
1974f250's Avatar
1974f250
late 1999 F-250 with 195,000 miles
In the last week and about 300 miles of driving it has sputtered about 30 times and died 4 times. The check engine light has come on 3 times after a sputter but the light turns off the next time I start the engine. When it dies it starts right up without any problem. My code reader wont read this truck, I can only clear the light. I thought I got some bad diesel (only 3.5 gallons) that had water in it. I've tried the common cures I could find on the forum. Put some water treatment in the tank, changed the fuel filter, drained the water separator a few times. It usually has this problem when the engine is cold but sometimes after it is up to temp. It's almost always under very light acceleration or cruising. I'm thinking it might be injectors or fuel pump. I just changed the oil also, I read on here low or dirty oil can effect the HPOP. I'm new to diesels, any ideas?
Old Jun 25, 2009 | 08:36 PM
zx250's Avatar
zx250
Of the next Riffraff East
Sounds like a bad CPS. Have you had the recall done yet? If not, it's free although some of us likes the old black ones better.
Old Jun 25, 2009 | 08:40 PM
F350-6's Avatar
F350-6
CPS is where I'd start too. You can change it yourself with a new one from Ford for about $25. If that doesn't fix it, it's a good idea to have a spare anyway.
http://www.guzzle7pt3.com/cps.php
Old Jun 28, 2009 | 11:47 PM
1974f250's Avatar
1974f250
Thanks, the problem was the CPS. It already had the recall. I got one for $28 from Car Quest.
Old Jun 29, 2009 | 08:33 AM
zx250's Avatar
zx250
Don't want to scare you, but the aftermarket CPS are very prone to problems and failures. You can get the QEM new style ford (gray one) for about the same money. If you run the carquest one, get a spare because I am fairly certian you are going to need it.
Jackedupfordtough
Jun 8, 2015 08:51 AM
Skyhawk Greg
73
Sep 15, 2014 10:29 AM
ChrisMelton78
Aug 29, 2013 03:06 PM
809taino
Modular V8 (4.6L, 5.4L)
Feb 3, 2013 09:15 PM
F350Scott
18
May 12, 2009 10:59 AM
