Where to cut Downpipe???
Old Jun 25, 2009 | 04:48 PM
Brown Falcon's Avatar
Brown Falcon
Where do I cut the old downpipe to get it out?
Do I cut from the top or from under the truck? Just doesn't seem like a lot of room to get in there from the top...
Installing my new 3" DP this weekend... any other tips?
Old Jun 25, 2009 | 04:53 PM
BlueMule's Avatar
BlueMule
Disconnect it from both top and bottom and raise it up as far as it will go and hold it there with a jack and then cut as low as you can from the top. If you do it right you'll only have to make just the one cut.
Old Jun 25, 2009 | 05:35 PM
chris64's Avatar
chris64
Could you take some pics? I will be putting an exhaust system on also. Thank you, C
Old Jun 25, 2009 | 05:45 PM
BlueMule's Avatar
BlueMule
There's some pics in this thread:
https://www.ford-trucks.com/forums/7...tion-pics.html
Old Jun 25, 2009 | 05:58 PM
Brown Falcon
I'll try to take pics and do a write up on it. If the weather holds up anyways...
Old Jun 25, 2009 | 06:18 PM
wildstang's Avatar
wildstang
VT Chapter Ldr
Spend the extra money and get some good long metal cutting blades. I had good cutting blade but it was a little short so I had to do multiple cuts. Do like BlueMule says and get it up as high as you can.
Old Jun 25, 2009 | 06:25 PM
Brown Falcon
I've got a good long metal cutting blade... The all the exhaust is off besides the dowpipe. Cat was already deleted and I sold my stacks so all I had was a short piece of straight pipe let anyways.
Gotta replace my CPS this weekend too since that's acting up again.
Old Jun 27, 2009 | 12:27 PM
Brown Falcon
Ok, time to complain here... I HATE TOOLS WITH BATTERIES!!!!
Used two batteries in a Sawzall to get about halfway through the stock downpipe... Now I have to wait till the batteries recharge to finish cutting it! And I'm stuck at home till the new pipe is in cause my wife took her car to a baby shower.
I really need to buy a sawzall of my own... borrowing my friend's 18V battery powered one sucks.
