eather dependency
Old Jun 25, 2009 | 04:12 PM
estennett's Avatar
estennett
Question eather dependency
I just got this 89 F-250 non-turbo diesel. did about 500 worth of work so far wraped up the diesel and trans leaks and replaced starter and batts. but where i am at now is it will not start without assistance from some sort of starting fluid. i heard it has become dependent and the habit can be broke. it will start normal about and hour after running but any longer i have to use some fluid again. anyone know how to break my "drug" addicted diesels habit?
Old Jun 25, 2009 | 04:24 PM
wreckinball's Avatar
wreckinball
motocraft beru plugs all around, a good wired(functioning) glow plug system, or like in my case a common sense manual gp system with a momentary switch. Mine was the same way and it was because of the GP Controller crapping itself. I bypassed it and it will start first time every time(knock on some friggin wood someone)
WB
edit, oh and when you decide let me know and i will direct you to the right diagrams. Second, when the system is up and running, dont ever use that crap again, the ether that is......last last last ditch effort to start only.
Old Jun 25, 2009 | 04:27 PM
rupejosh's Avatar
rupejosh
make sure the glow plugs are up to snuff then return lines
Old Jun 25, 2009 | 04:52 PM
estennett's Avatar
estennett
shall do thanks
Old Jun 25, 2009 | 05:09 PM
Festus Hagen's Avatar
Festus Hagen
Methanoholic
Test that you get power to the Glow Plugs with a test light...
Unplug a GP, Connect one end of a test light to the GP wire, the other end to ground, place it so you can see it when you turn the key on, turn the key on...
Does it light up?
To do a Test Light test of the glow plugs.
1. Unplug the GP
2. Connect one end of the test light to + battery
3. Touch the other end to the terminal on the end of the GP (where you unplugged the harness)
If it lights the chances are it's good.
This test is very susceptible to miss diagnoses and should only be used for a quick reference.
To do a positive test use a volt/ohm meter and test the ohms between the terminal and base. Should be .5 to 1 ohm resistance.
-Enjoy
fh : )_~
Old Jun 25, 2009 | 08:15 PM
wreckinball
festus i think i got the exact same response from you when i posted this as my first post. Funny to see it from the other side now.
Old Jun 25, 2009 | 10:12 PM
fellro86's Avatar
fellro86
Glow plugs are key... My old man's 84 was fired on ether for years, I moved back to the area after being gone for several years and started working on it. Put in new glow plugs and injectors, fires just fine now without any ether.
Old Jun 25, 2009 | 11:13 PM
88f150302's Avatar
88f150302
i have a problem starting my truck when its warm it starts fine when its cold but if i shut it off i have about 5 min to re start it or it wont start till it sits for a couple hours anyone have any ideas?
Old Jun 25, 2009 | 11:15 PM
88f150302's Avatar
88f150302
oh hey a little info about the truck might help its a 92 7.3 with a e4od
Old Jun 26, 2009 | 12:54 AM
rupejosh's Avatar
rupejosh
i would say start looking for an injection pump
Old Jun 26, 2009 | 01:21 AM
Festus Hagen
Methanoholic
Yup, I agree, IP.
-Enjoy
fh : )_~
Old Jun 26, 2009 | 09:38 AM
wreckinball
Originally Posted by estennett
shall do thanks
how is it going? get anywhere?
Old Jun 27, 2009 | 12:20 AM
88f150302's Avatar
88f150302
well thats not what i wanted to hear haha i asked in a different post but dose anyone know if a ip off of a chevy 6.2 will work someone said it may run backwards from the ford but i havent gotten a deffinate answer it looks the same thanks for the info
Old Jun 27, 2009 | 03:13 AM
rupejosh's Avatar
rupejosh
i wouldnt do it is it a stanadyne db2?
Old Jun 27, 2009 | 06:23 AM
fellro86's Avatar
fellro86
They are similar, but hookups are different. I don't remember all what is changed, but they are very close.
