different c-4 trans cases?
Old Jun 24, 2009 | 10:53 PM
hotroddually's Avatar
hotroddually
i have looked around here and can't find anything that helps me identify the trans we are dealing with. a friend is trying to swap his c-4 trans out of his 79 f-100 short box 2 wheel drive. he got a trans out of a 74 comet.the car has a 302 and the trans was supposed to be a c-4,but he says it looks different at the bellhousing.he doesn't think they are the same size.the info i have found tells me its a c-4,except the bellhousing area is different. i was told there is a "big" case c-4 and a "small" case c-4. is this true? if this is true,that would make sense why it is different.i don't think we can swap these two transmissions. i also have given him my c-6 out of a '77 E-150 ford van with a 351 winsor.we have everything from this van,drive shaft,rear diff,engine,cross member,etc. i know we will need to get the drive shaft shortened to use the c-6 combo. any help offered would be great.
Old Jun 25, 2009 | 12:31 AM
85e150's Avatar
85e150
Have only heard of "pan fill" and "case fill" as in where the dipstick/fill tube goes into the case. Also referenced is bell size. See info here:
http://www.tciauto.com/Products/Ford...#transmissions
including bell info:
http://www.tciauto.com/Products/Tech...llhousings.asp
Are these both aluminum cased transmissions?
C4 pic, you can find others.
Beware you are not dealing with the aluminum bell, iron case FMX:
http://www.charlietranny.com/FMX.htm
Old Jun 25, 2009 | 10:12 PM
hotroddually
thanks 85e150six4mtod, for the trans info links. it looks to me like he has an got an FMX instead of a c4 from the 74 comet. i think we should try to go with the c6 i gave him,and the drive line parts that go with the c6. we dont have the drive line parts that went with the FMX,so that could just become a whole new challenge we dont really need. thanks for your help.-billy
Old Jun 26, 2009 | 12:52 AM
85e150's Avatar
85e150
Glad it helped.
dig'umz
Feb 18, 2013 10:50 PM
godblessmud
Jan 30, 2008 07:09 PM
6eightF250
Jan 7, 2008 10:55 AM
Dru71
Jan 5, 2007 06:11 AM
benwantland
Sep 22, 2006 09:04 AM
