I have 15x10 wheel on my 87 FSB and would like to go to a 15x8 or 15x7.5. Heading out to the junk yards to see wha I can find. What year model Bronco and trucks have the same wheels with the 5 on 5 bolt pattern?
Every Bronco and Ford 1/2 ton (F-series and E-series) fullsize has the same bolt pattern... the same is true for fullsize Dodge trucks through the mid 90's and many Jeep vehicles as well. OEM Bronco/F-150 wheels are 15x7 5/8" for the alloys and 15x8 for the steel if I my memory hasn't completely failed me. If I am wrong someone here who remembers correctly will say so. And by the way, the bolt pattern is 5 on 5 1/2" not 5 on 5".
You are correct in the size. It is 5x5.5 or 5x139.7mm
All jeeps with 5 bolt up until 85...some dodge ram trucks
Tell you what ..here is a link to a site with a bolt pattern reference http://www.discountedwheelwarehouse...._Reference.cfm
