exhaust diameter question
Old Jun 24, 2009 | 01:37 PM
F-250 restorer's Avatar
F-250 restorer
Hey guys--
My Hedman header came with the collector attachments/pipes so they can be welded to for the rest of the exhaust system.
I notice the pipe is 2". It is a dual set up. From what I've read, the best size is the 2.25" diameter pipe.
Should I stick with what Hedman sent, or switch to the larger 2.25" pipe?
Old Jun 24, 2009 | 02:04 PM
AbandonedBronco's Avatar
AbandonedBronco
I'm not sure on the best course, but an idea may be to have the pipes go into 2" in / 2.25" out mufflers?
Old Jun 24, 2009 | 05:53 PM
ceetwarrior's Avatar
ceetwarrior
You don't really need those attachments that come with the header kit, a good exhaust shop can make those really easily in 2-1/4" for you. I'd run 2-1/4" all the way. 2" is tiny stuff!
Old Jun 24, 2009 | 06:25 PM
Harte3's Avatar
Harte3
I don't remember which one but one of the muffler manufactures has a chart that recommends pipe size according to engine size. 2" or 2 1/4" works fine on these engines to maintain desired velocity.
Old Jun 24, 2009 | 06:42 PM
6CylBill's Avatar
6CylBill
Keep the 2'' half way and open it up to 2.25 or 2.50. Ideally you want to start narrow and open it up as you get to the rear bumper.
I agree completely. No need to go any larger than 2.25 on a nearly stock 300.
Old Jun 26, 2009 | 10:01 AM
76F100guy's Avatar
76F100guy
Ah, no. If you're going to use different sizes, it's the other way around. As the exhaust cools, going down the length of the truck, it requires less volume, not more.
FWIW, I have (2) 2" headpipes off the EFI manifolds, into a Flowmaster Y, and 2 1/2" with a generic turbo all the way out.
Old Jun 26, 2009 | 10:21 AM
6CylBill's Avatar
6CylBill
I have read through dozens of posts and have done a lot of research on this. I'll stick to my own method. A good way to find out is to take a truck and run it on a dyno with the exhaust identical, except for which end has the larger piping. I'll not swear to anything but from what I have read it's best to run narrow piping at first and then open it up.
Old Jun 26, 2009 | 01:49 PM
91Bronc300's Avatar
91Bronc300
I would use the two inch pipe that is supplied to go back from the collector. And then go from that 2 inch into a 2.25 or 2.5. I don't believe the size after the 2 inch is really too critical unless you make it huge. But my thinking is that the pulse of hot gas from a single cylinder exhausting will travel down it's own header tube and then at the point it reaches the collector it will take some of the positive pressure from inside the other header tubes and drag it out with it to make a slight vacuum. This will then scavenge the exhaust pulses that are next in line. If you use a little bit larger pipe right at the collector the exhaust pulse will immediately loose a little velocity when it exits it's tube and enters the collector and transfer a slightly weaker vacuum signal back up the other header tubes. Reducing scavenging slightly. So I think using the 2 inch piece, however long it is, 12 or 18 inches or so, immediately after the collector, and THEN going slightly larger will improve your scavenging. That is probably why they supply the headers like that.
Old Jun 26, 2009 | 02:16 PM
6CylBill's Avatar
6CylBill
Good thinking 91Bronco300. I believe you are correct.
Old Jun 26, 2009 | 02:44 PM
91Bronc300's Avatar
91Bronc300
Thanks Bill. Although I think you would know more about this subject than me. By the way though, since I'm no longer a crime fighter by night I think it's time to unmask my true identity.................
Hereafter I shall be known as Steve (91Bronc300 just has no personality behind it)
I'm sure you were dying to know
Old Jun 26, 2009 | 03:58 PM
6CylBill's Avatar
6CylBill
I try to remember people's names on here but I often get names mixed up. I just wish people would put their names in their sigs!! Haha!
Alright Steve I'll try not to call you James.
Like I said, I've done a lot of research on exhaust, and although I couldn't begin ti provide concrete facts (if I had anything, it was all on my other computer that is in storage). That's why I won't debate; I can fully understand why people think it should be opposite.
Old Jun 26, 2009 | 05:14 PM
dustybumpers's Avatar
dustybumpers
I welded 2 1/4' pipe to the collectors that came with the headers. I ran a 2 1/4 duel in/out flowmaster and 2 2 1/4 tailpipes truck has duels all the way
Old Jun 26, 2009 | 05:20 PM
91Bronc300's Avatar
91Bronc300
Yeah, me too. I agree with the idea of the exhaust cooling as it gets further down the exhaust pipe and requiring progressively smaller tube diameters to maintain a fixed velocity. But to setup an exhaust system to properly take advantage, after the collectors and then the initial 18 inches or so of 2 inch pipe would be to complicated. You would then have to inlet into a 2.5 inch pipe or so and then measure the temperature and velocity at that point, figure out what your temperature and velocity loss are going to be at the tailpipe, do a bunch of math that's over my head for sure, figure out what the ideal taper is, then have a custom tapered pipe made that's about 8 feet long or so. Any attempt to neck down the exhaust pipe in steps is going to create a reversion where the steps meet that would surely negate any gain in velocity the smaller pipe would give you. So I think the idea of 'neck down the exhaust as the gases cool to maintain velocity' is sound theory but impractical to implement.
Old Jun 26, 2009 | 06:21 PM
ceetwarrior
For sure. And on a 150HP 300-6 I can't see how it makes a difference. There is something to be said about "tuning" an exhaust on a indy car, or nascar, or something that will really respond as they have specific 700+ HP engines.
Dude, think about what we have... a 40 year old design one hundred and fifty horsepower 6 cyl engine, LOL!!
Old Jun 26, 2009 | 07:06 PM
6CylBill's Avatar
6CylBill
I used to think that way too.
As it turns out, you can lose a lot of low end torque if you do things wrong. I did things wrong, but on purpose. I love to hear my truck roar. If I need to pull something my gears do the talking.
