bed rust repair
Old Jun 24, 2009 | 12:05 PM
sk8kat1's Avatar
sk8kat1
bed rust repair
yes this is my ne wto old ford trucks barrage of questions lol
my bed on my 78 f100 2wd long bed that I just got is ruting in the wheel arches and then just the flat bottom center of the bed floor .
I saw the patch panels on LMC but I was not sure if there was a better route that you folks have found or the quality of teh LMC panels
is it easier , cheaper and better to find a used bed in better shape or are beds in good shape rarer than lips on a bird ?
please let me know what you guys have found to be the best route
Old Jun 24, 2009 | 01:54 PM
Witty73's Avatar
Witty73
Welcome to FTE. For me it was real difficult to find a good box. Welding in patch panels is not that difficult, however, I as well as most of the guys here would encourage you to support the sponsors of this forum, prior to turning to LMC. Post some pics and I am sure you will get some great advice and replies.
Old Jun 24, 2009 | 01:56 PM
sk8kat1's Avatar
sk8kat1
which sponsor would your recommend for bed / cab corner and lower door patch panels?
Old Jun 24, 2009 | 02:03 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
Blue Oval is pretty good for sheetmetal. http://www.blueovaltruckparts.com/
Josh
Old Jun 24, 2009 | 11:25 PM
smithwoods's Avatar
smithwoods
At one time you could order a new bed floor and headboard from Ford, I know because I did it in the late '80s early '90s. Maybe numberdummy can scout you up one. nothing fits as good as real Ford parts. repops are getting better
Old Jun 25, 2009 | 04:21 AM
Diesel_Brad's Avatar
Diesel_Brad
I wouldnt mess w a patch panel. I would put a whole side on. It makes for a nicer job and you know what you have then. Especially if you are not that great at body work
Old Jun 25, 2009 | 05:04 AM
duste's Avatar
duste
Diesel Brad is right there, if you can afford it , then replacement panel are the way to go. They are $330/ side here in Canada for good quality panels. Panel bonding (gluing) the panels on is now the best , strongest and fastest way of replacing a side panel. Once you do it this way once you will never weld a panel on again plus it's as simple as follow the instruction and make sure you have about 12 pairs of vise grips or clamps. Good luck and welcome to the site.
Old Jun 25, 2009 | 09:37 AM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Food for thought??
I agree with the last 2 statements, if you can afford it, just change the whole bed side. The dentside and race track molding can be fun, if it applies to your truck.
Also a great time to do the rear, inner fenderwell modification to prevent mud/moisture getting trapped inbetween the inner/outer walls.
Do a forum search to get the low down on it, cool mod idea I read about on here. Also maybe time to go to the duel tank route, buy your double flap, gas cap side.
Old Jun 25, 2009 | 11:36 AM
Diesel_Brad
O you can go w the replace the whole bed route like i am doing, if you have nothing left to put sides on. This bed and cab came from New Mexico
<a href="http://s108.photobucket.com/albums/n29/diesel_brad/?action=view&current=000_0533.jpg" target="_blank"><img src="http://i108.photobucket.com/albums/n29/diesel_brad/000_0533.jpg" border="0" alt="79 f150"></a>
Almost no rust. Best thing to start w. It still need body work but what i like is that it will all be genuine ford
Old Jun 26, 2009 | 11:35 AM
sk8kat1's Avatar
sk8kat1
never heard of the panel bonding and I am curious .. after teh panel is " bonded in place what tis the paint prep that takes place ... do you grind smooth .. do your use self ecth primer ... does make teh primer and paint lift over time ?
hmmm I am very curious
Old Jun 26, 2009 | 11:51 AM
Diesel_Brad
1 Grind down to bare metal, where the two panel meet.
2 Put the panel adhesive over the bare metal.
3 Put panel on and clamp together for at least 8 hours.
4 If you did it right , there will be no visible adhesive, if not just sand any
"extra" off and prep as you normally would.
Old Jun 26, 2009 | 12:22 PM
sk8kat1's Avatar
sk8kat1
so does it require an overlapping joint or is it a butt joint where the two panels meet ?
or... is it that you just apply the bonding agent to the edges that touch --
I was imagining that they were bonded kinda like dry wall work float and tape the joint type thing
I have a family member that works for 3M so I can get a discount on the bonding agent- so I am rather interested in the process and longevity of the application on a real world truck
Old Jun 26, 2009 | 02:04 PM
Diesel_Brad
Overlap joints ONLY!!!! It is in place of spot welding...NO burnt of paint to start rust
Old Jun 26, 2009 | 02:33 PM
sk8kat1's Avatar
sk8kat1
do you lose teh bond in part when you grid down the edge and then it changes the profile of panel , yes
I might be missing the process entirely -- got any pics of teh process?
Old Jun 26, 2009 | 02:46 PM
Diesel_Brad
<a href="http://s108.photobucket.com/albums/n29/diesel_brad/?action=view&current=000_0600.jpg" target="_blank"><img src="http://i108.photobucket.com/albums/n29/diesel_brad/000_0600.jpg" border="0" alt="Photobucket"></a>
<a href="http://s108.photobucket.com/albums/n29/diesel_brad/?action=view&current=000_0601.jpg" target="_blank"><img src="http://i108.photobucket.com/albums/n29/diesel_brad/000_0601.jpg" border="0" alt="Photobucket"></a>
<a href="http://s108.photobucket.com/albums/n29/diesel_brad/?action=view&current=000_0602.jpg" target="_blank"><img src="http://i108.photobucket.com/albums/n29/diesel_brad/000_0602.jpg" border="0" alt="Photobucket"></a>
OK Class? Now it is time for milk and cookies then nap time
