Turbo Questions
Old Jun 24, 2009 | 11:00 AM
Sparkplugless's Avatar
Sparkplugless
Turbo Questions
I have noticed my turbo making funny noises at shift points, especially 4th. It sounds like the bearing wobbling, and a whoosh. I don't know if it's surge or a bad turbo. I've seen several remedies for surge, new housing, wicked wheel, and the van turbo (am I correct in assuming that the van is simply a turbo out of an Econoline?) Do they do more than take care of surge?
I've noticed a lot of talk about the GTP38R, I've read from others that mpgs go down somewhat with the GTP38R, and I seem to recall someone saying lowend tends to suffer as well. I like more power (does Binford make a turbo?) Sorry, a little Tim the tool man coming out. Anyway, I like speed, but I need pulling power.
What do you think is wrong w/ my turbo, and what do you all recommend? Thanks.
Can't wait for RiffRaff East
Old Jun 24, 2009 | 11:13 AM
Pocket's Avatar
Pocket
Not sure where you heard that. Mileage with my 38R didn't change, and on the bottom end it spools at least as quick as the stock turbo.
Old Jun 24, 2009 | 11:20 AM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Have you recently went to an open air filter? Sounds like the whoosh you hear from the installation of the 6637.
Old Jun 24, 2009 | 11:42 AM
big poppa's Avatar
big poppa
With my 38R I haven't noticed mileage loss and it does spool up fast at the bottom end and all thru the power band. Van turbo is out of a Econoline your correct, and their non-wastegated.
Old Jun 24, 2009 | 12:29 PM
duck fan's Avatar
duck fan
Because racetruck
There are a couple of van turbos on the classifieds right now. Grab one up while they are available!
Old Jun 24, 2009 | 12:49 PM
mudmaker's Avatar
mudmaker
Loss of mileage is probably due to mashing the pedal more!LOL!
Old Jun 24, 2009 | 12:50 PM
Sparkplugless
I have switched to a 6637 recently, as well as a DP.
But the noise seems more than just the whoosh, and it continues until I let off the throttle.
Old Jun 24, 2009 | 01:11 PM
miller_feed
You may be getting surge. I would get it bad with the stock turbo and the DP. You may want to get a new housing or a WW.
Old Jun 24, 2009 | 01:34 PM
Mike F250's Avatar
Mike F250
I get the same noise with my 6637 installed. From everything I've read here it is not surge in my case. Boost gauge shows constant pressure. It sounds like a massive amount of air being sucked through the filter.
Old Jun 24, 2009 | 01:41 PM
miller_feed
Does it happen when your trans shifts? When you go WOT then let off the pedal? If it does this, that is the nature of the beast. The excess boost has to go somewhere once the RPM goes down, so it blows back out the intake and filter.
Old Jun 24, 2009 | 01:48 PM
Sparkplugless
Yes when it shifts, and sorry, what is WOT ?
Old Jun 24, 2009 | 02:01 PM
miller_feed
WOT= wide open throttle. Most people enjoy the whoosh sound.
ZombiePopper
13
Feb 28, 2015 05:08 AM
Sparkplugless
59
Jul 9, 2009 12:19 PM
ernesteugene
33
Nov 2, 2007 12:25 AM
Lance_I
Nov 30, 2006 04:39 PM
red4x4
Mar 29, 2004 04:13 PM
