will they fit?
Old Jun 24, 2009 | 10:50 AM
sk8kat1's Avatar
sk8kat1
will they fit?
I am a f100 newbie but not new to old cars and trucks .
I just picked up a 78 f100 2wd long bed w/ a c6
I also found a set of 5 1995 15" bronco rims and tire - I f I am not mistaken they are the same bolt pattern as my f100 . I have not bought them yet but are pretty cheap .
the question is if the rims have 31x10.5x15's on them will they fit and run on the truck with out rubbing or some other issues
thanks in advance for the help
Old Jun 24, 2009 | 05:23 PM
JesusRocks's Avatar
JesusRocks
Shouldnt have a problem. And even if they did rub, it would only be very little at max steer.
Old Jun 25, 2009 | 09:52 AM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
See if you can "test fit'm" to make sure before cash changes hands. IMO
Old Jun 25, 2009 | 10:47 AM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
I ran 31" BFG TA/KO on my 2wd. Only rubbed either when backing up with the steering full lock (rubbed on the radius arms), or with steering full lock pulling into my driveway (tire tread would sometimes catch the wheel well lip)
Nothing major in either case... I was also running some 1995 F150 steel wheels.
Josh
Old Jun 25, 2009 | 10:20 PM
sk8kat1's Avatar
sk8kat1
Ok I got the rims and tires 4 alum rims in very good shape - tires have bout half tread left - and 1 painted steel rim with an almost new 265 size tire - rims a bit rusty so the paint is peelin a lil - seems more surface/cosmetic rust
All for $300 is that a pretty fair deal ?
