2001 expedition ABS problem
Old Jun 24, 2009 | 12:51 AM
softie's Avatar
softie
Hi guys, I recently had some work done to my car. I had the d/s ball joints and tie rod replaces and also had a leak in my rear diff fixed. Now my ABS is on. I've also noticed that my emergency break doesn't really stop my car from rolling when at a full stop. So I'm pretty sure that means time for new breaks even though I have no stopping issues. But back to the ABS light. Is there any way to tell what the exact problem is? Ie: a code or something? If so where can I find out how to do this?
Thanks in advance for your help
Old Jun 24, 2009 | 08:35 AM
alloro's Avatar
alloro
It's likely that during the course of these repairs a sensor wire got pinched at one of the front wheels or something happened to the sensor on the differential
Old Jun 24, 2009 | 06:34 PM
khangmai's Avatar
khangmai
Softie,
No emergency brake is likely caused by leaking rear axle seals. Just fix the seals and clean up the emergency brake shoes with the brake cleaning fluid. These shoes are hardly worn out. The emergency brake shoes are located inside the rear rotors. ABS light is very likely caused by a bad ABS sensor located on top of the rear differential or sensor was not re-connected. You mentioned a leak at diff. was fixed, was it a pinion seal leak or axle seal leak?
Old Jun 24, 2009 | 07:02 PM
softie's Avatar
softie
Originally Posted by khangmai
Softie,
The leak was coming from the back plate of the diff..... I dont know much about cars really. I grabbed the sensor today and it seems to be plugged in. Also when I turn on the car the ABS light wont go off until I take my foot off the break pedal.
Bib
Mar 19, 2017 07:11 AM
CBRR
Aug 15, 2016 05:08 AM
KDCS
Jul 10, 2013 11:16 AM
JCHH
6.4L Power Stroke Diesel
Mar 24, 2010 10:52 PM
