Sponsored by: Real Truck
Understanding my torque converter?
Old Jun 23, 2009 | 03:26 PM
kittyhawksurf's Avatar
kittyhawksurf
Talking Understanding my torque converter?
Okay, so I keep posting a bunch of dumb threads about stuff I should already know, but it's been about 15 years since I spent time on my own vehicles. I bought my new truck a couple of weeks ago and I wanted to understand a little more about my torque converter. So of course, I googled it. I didn't get as many answer as I thought I would, so I decided to make yet another thread requesting help with my truck. I guess the good side to all of it is that I have been giving people "positive feedback." for helping me with things (MODS - I love the feedback system!).
So a couple of quick questions:
What is the main purpose of my torque converter? Is it to push my bigger tires, or for towing, or...?
How do I know what torque converter I have and is it near my axles where the transition is between axle and drive shaft?
Any basic torque converter information would be helpful.
Thanks
Old Jun 23, 2009 | 04:38 PM
J_E_Summit's Avatar
J_E_Summit
Let me start the advice by mentioning that the torq converter is in the bell housing between engine and transmission (where a clutch would be)
I read a really good article about torq converters, I will see if I can find it, as it will save me some typing
Old Jun 23, 2009 | 11:03 PM
ReAX's Avatar
ReAX
Think of the TC as a fluid coupling between the engine and transmission. The only time your engine output is exactly equal to the transmissions' input is when the clutches inside it engage. This is computer controlled and acts like a manual transmissions clutch, manually linking the engine to the transmission with clutch discs and clamping force.
There are a bunch of vanes in the TC, these move the fluid which moves other vanes. This is the limit of my knowledge, but I've read some articles that I can pass on some information I recall. Those vanes push the trans fluid which push another set of vanes which drive the transmission. There is a multiplication of torque that occurs from driving the fluid into the other vanes. So it can actually input more torque/hp than the engine produces, but I think this number is small. Then there is the "stall speed", basically it's the speed you want to spin the engine up to launch.
Check out http://www.converter.com/ These are heavily followed converters in some circles.
Old Jun 24, 2009 | 12:54 AM
Flaw's Avatar
Flaw
Here is a YouTube Video that looks to be about 10-15 years old. It isn't the most informative video, but it gives you some more of an idea.<br>Torque Converter Video
Old Jun 24, 2009 | 10:15 AM
firemanpat29's Avatar
firemanpat29
http://auto.howstuffworks.com/auto-p...-converter.htm should be all you ever wanted to know
Old Jun 24, 2009 | 10:18 AM
J_E_Summit's Avatar
J_E_Summit
Thats the article that I saw in the past. I couldn't find it again.
Old Jun 24, 2009 | 10:46 AM
redford's Avatar
redford
FTE Leadership Emeritus
Basically, imagine 2 fans. One is driven by a motor, the other is freewheeling. When air from the first one hits the second one, it causes the second fan to spin.
A torque converter is like that, but instead of fan bladed it uses impellers (turbine looking things). The coupling media is fluid instead of air, and the whole thing in encased in a metal donut. It sits between the transmission and the engine, coupling the engine torque to the transmission.
Old Jun 25, 2009 | 08:47 AM
edjunior's Avatar
edjunior
That, Redford, is a dem fine explanation and visualization. Brought down to laymens terms!
Old Jun 25, 2009 | 09:41 AM
kittyhawksurf
Okay thanks. From the information you guys gave it seems that every manual transmission has a TC. I thought TCs were usually added for increase torque. Guess I was wrong about that one.
My truck got a "new HD Torque converter" shortley before I bought it. What is the significance of the HD?
Old Jun 25, 2009 | 09:51 AM
kittyhawksurf
The how stuff works article was AWESOME.
Old Jun 25, 2009 | 10:43 AM
ReAX's Avatar
ReAX
All automatics (not sure about the constant velocity types) have torque converters. Manuals use a clutch/pressure plate setup to connect the engine to transmission.
HD can mean anything from better construction over the standard model to upgraded features. Now if it's a clutch, HD can be heavier a pressure pressure plate, better gripping clutch compound, hotter running clutch compound, different friction designs.
Old Jun 25, 2009 | 12:00 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Manual transmissions don't have torque converters, only automatics.
That is what a torque converter does. It converts RPM into increased torque. A torque converter can output up to twice the torque that the engine produces. See the article from www.howstuffworks.com mentioned above to see how it does that.
Old Jun 26, 2009 | 05:56 PM
bryyce62's Avatar
bryyce62
When a torque converter fails, what exactly fails?
Old Jun 26, 2009 | 06:31 PM
Mark Kovalsky
There are a few ways it can fail. The torque converter clutch can wear out. The stator can fail, changing the torque converter into a fluid coupling. The third way I can think of is the blades can bend, making the torque converter just a large hunk of oil filled metal junk.
Old Jun 28, 2009 | 03:26 PM
kittyhawksurf
[quote=Mark Kovalsky;7645961]Manual transmissions don't have torque converters, only automatics.
sorry, but that is what I meant. all automatics have TCs
