Air cleaner vacuum routing
Old Jun 23, 2009 | 03:21 PM
79 Punisher's Avatar
79 Punisher
Hello everyone i have a 79 ford 351m with a Motorcraft 2150 and California emissions with a C6 tranny. I need some info in what two hoses come off and attach to the Air Cleaner Bi-Metal Sensor. I know one ends goes to a vrdv (vacuum delay retard valve, blue and white in color) and that is routed to the vacuum motor on the end of the air cleaner. I have a diagram here that reads that the other nipple for the Air Cleaner Bi-Metal Sensor goes to manifold vacuum is this correct?
Old Jun 24, 2009 | 03:24 AM
Jermafenser's Avatar
Jermafenser
Some goes to the vacuum reservoir next to the battery. Some ends at manifold vacuum. So it sounds you are correct in that case.
