Level Kit installed (pics)
Old Jun 23, 2009 | 02:47 PM
04XLTRUNNER's Avatar
04XLTRUNNER
before:
after:
stock platinum 2x4 on 22's next to mine on level kit:
time to get some 35's now.
Old Jun 23, 2009 | 10:25 PM
Jeremy2788's Avatar
Jeremy2788
Looks good.
Old Jun 23, 2009 | 10:34 PM
tcarro2001's Avatar
tcarro2001
I like it a lot. I have been thinking about doing it for a while. If I get this done, I will have to wait to get new tires. In your opinion, how does it look with the stock tires and rims (same as mine). It may be a year or so before I change tires, but would like to get this done now, as long as it doesn't cause the stock set up to look TOO undersized.
Old Jun 23, 2009 | 10:48 PM
broncobran68's Avatar
broncobran68
How do you like the stance? Is it level, nose up, slight rake? Do you feel like you need an aal or block now? My truck is bugging me but $100 for a block is hard to stomach.
Old Jun 23, 2009 | 10:55 PM
tcarro2001's Avatar
tcarro2001
Is the 2.5" a little too high in the front? What's bugging you about it? I am soooo close to getting a leveling kit on mine, but don't know "jack" about it.
Old Jun 23, 2009 | 11:16 PM
broncobran68
Yeah it "appears" nose high. The bed is about level. I just think that with the body lines and fender heights on these trucks that some rake is necessary to provide a pleasing look. My superduty and '89 f150 looked great dead level. But they have more square bodies.
There are plenty of threads on this subject. Just use the search button, read, and reread. Check out the 04-08 forum too. Not everything applies 100% but still lots of good info.
Old Jun 24, 2009 | 04:27 AM
Fuzzy Willy's Avatar
Fuzzy Willy
I put the ReadyLift 2" Leveler Kit on mine and it measures exactly the same 39.25" from floor to underside of fender well, front and rear.
Old Jun 25, 2009 | 11:45 PM
04XLTRUNNER
i was thinkin about taking out the 2in factory block and putting in a 3in block because it looks like the front it up a little more than the rear but i measured it today and the rear is actually 1/4in higher than the front. it sits right at 39 1/2in from the ground.
but i like the stance. it will be gettin larger tires, the stockers are way to small. im going with 35" mud grapplers.
YellowSled
Sep 20, 2024 01:55 PM
1965HHORunner
22
Jun 17, 2010 11:01 AM
rockcrawler_101
19
Aug 22, 2009 11:27 AM
jerg_064
Oregon Chapter
May 31, 2009 02:54 AM
Snowking
Mar 25, 2009 08:54 AM
